Philips 50PUS6554/12 needs a dump.
  • yoritomo
    • Sep 2012
    • 146
    • Belgium
    Phiilps 50PUS6554
    Chassis TPM14.6E LA
    Hello everybody
    I checked the power supply of the TV set which is good , and now it appears clearly to be a software problem.
    I could not find any dump for this model, can you help me ?
    Thank you and have a nice day.
  • yokoono
    • Apr 2010
    • 478
    Chassis TPM14.6E LA ???
    • Diah
      • Feb 2013
      • 6355
      download from here any one , only upgrade_loader
      • yoritomo
        • Sep 2012
        • 146
        • Belgium
        Thank you Yokoono, I just see now I made a mistake in chassis number, it is actually TPM19.6E LA. I am going to make correction immediately in the post
        Thank you Diah, following this link, I could not find this model in the page. I don't know exactly what to download.
        • lotas
          • Jan 2016
          • 4512
          • Russia
          Do you need a dump eMMC for a programmer or a service firmware via USB?
          • yoritomo
            • Sep 2012
            • 146
            • Belgium
            I may try a USB flash, because it has reaction from power on button, the LED goes off, but if it is flashing only by menu that is not going to work. Sometime a remote control key combination launch the flash, I don't know about this one.
            I don't know also if it is possible to try a ISP flash of the EMMC with this board.
            • lotas
              • Jan 2016
              • 4512
              • Russia
              Yes, you can also use ISP. Just make a copy of your dump (backup), and then experiment with USB firmware.
              • yoritomo
                • Sep 2012
                • 146
                • Belgium
                So it is the way I will do, but I don't have that dump. It may also come simply from the BIOS.
                • lotas
                  • Jan 2016
                  • 4512
                  • Russia
                  Save your eMMC dump, just in case (since it contains the keys), and then experiment as you wish, so that you can later return everything back. If you need a dump, I'll give it to you.
                  • yoritomo
                    • Sep 2012
                    • 146
                    • Belgium
                    Yes please .Have you both dumps ? where to find it ?
                    • lotas
                      • Jan 2016
                      • 4512
                      • Russia
                      Why are both dumps? Only eMMC suffers here.
                      • yoritomo
                        • Sep 2012
                        • 146
                        • Belgium
                        How can you be sure ? Most of the time I only flash the eeprom BIOS and it works, it is not so often to be the emmc or Nand in trouble. Symptoms are often similar in both cases. In this TV set U409 seems to be the Bios.
                        • lotas
                          • Jan 2016
                          • 4512
                          • Russia
                          You know better, but unfortunately I don’t have BIOS.
                          Don't confuse the QFU1.1E LA, QFU1.2E LA, QFU2.1E LA chassis, where the bios is (spi flash M25P10 and NAND) and this chassis, where the eMMC is and the boot is from the BOOT1 partition.
                          • Diah
                            • Feb 2013
                            • 6355
                            at the link i gave to you search the site after 2019 model yours 6554 one of them... you will find many version of upgrade_loader firmware... only this fit to downgrade or upgrade.
                            but since yours screen 50 , this size 50 are rubbish over all brands, so disconnect the panel then see if the TV work yours sign will be the Optic Port lit Red
                            • yoritomo
                              • Sep 2012
                              • 146
                              • Belgium
                              Lotas: is it the post in Remont AUD ? the Dump 2Gb ? Ok I will give it a try and then lets see if working, thanks a lot.
                              Diah: I found one working link, all other ones are dead in that section, do you think such upgrade file might work in blind ? You are right I should try to disconnect the panel to find any short on it. Thank you
                              • Habble7
                                by Habble7
                                Suspected Cause:
                                Troubleshooting Attempts:
                                05-22-2025, 07:28 AM
                              • Mephysis
                                DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                by Mephysis
                                Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                03-27-2025, 02:34 AM
                              • hyperwood
                                [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                by hyperwood
                                I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                ✅ What I need:
                                • A working 2MB BIOS dump
                                • Matching NM-E471 Rev. 2.0, e.g. JY575
                                06-25-2025, 02:28 PM
                              • Andreas_de
                                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                by Andreas_de
                                Hello!
                                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                04-12-2025, 10:38 AM
                              • re-atari
                                Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                                by re-atari
                                Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                                Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                                02-03-2025, 06:49 PM
