Samsung LN32C450E1D
+ More Options
Posts
  • smuddge
    • Feb 2012
    • 96
    Samsung LN32C450E1D
    Have been searching through the forums to figure this out but haven't got a clear answer from other posts.
    I have a 32" LCD LN32C450E1D when it is plugged in the power light blinks a few times then goes out. The screen never turns on.
    I looked at the power supply etc and see nothing unusual about it.
    From my reading here I read that if i unplug the power from the main board and plug it back in it should turn on the backlight and this should verify the power supply is good.
    I tried that and it is in fact turning on the backlight which stays on until i unplug the power.
    So from my understanding it is a problem with the mainboard. How can i figure out what is causing the problem with the mainboard to fix it. I see them for sale usually in the 120$ range which is likely more than I can get if I fixed it and sold it.
    Any help would be appreciated.
    thanks in advance.
  • sordids999
    • May 2013
    • 2149
    • uk
    Re: Samsung LN32C450E1D
    posting pictures of the back of the tv showing the boards will help you more to get it fixed
    • smuddge
      • Feb 2012
      • 96
      mainboard bn96-15147A on sticker
      power supply bn44-00338B printed on pcb
      hope these are good enough.
      only have phone camera....
      • Agent24
        I see dead caps
        • Oct 2007
        • 4949
        • New Zealand
        What is the _exact_ LED error code? How many times does the LED flash? What colour is it?
        That will be a good start, I think. Some of the other guys here know what those codes mean, but "Flashes a few times" is not helpful to anyone.
        -David VanHorn
        • smuddge
          • Feb 2012
          • 96
          5 flashes red light then off and no more coming on unless I unplug it and plug it back in.
          • MagicSmoke
            • Feb 2011
            • 275
            According to shopjimmy.com there are multiple P/N's that will cross over and work with that set.
            http://www.shopjimmy.com/samsung-bn9...c450e1dxza.htm
            That exact P/N seems to be discontinued or out of stock at most places.
            • mmartell
              • Oct 2013
              • 3189
              There are no error codes, you are seeing the power supply attempting to come up. Was this not the model with the cold solder joint on one of the PS mosfets ? Have you tried hot air yet ?
              • Agent24
                I see dead caps
                • Oct 2007
                • 4949
                • New Zealand
                Really? I thought modern TVs often (especially big brand name ones) had power LED error codes, from what I read on the forum. Or is that only Plasmas?
                -David VanHorn
                • mmartell
                  • Oct 2013
                  • 3189
                  Sorry I should have said Samsung lcd/led can't say for sure about plasma but think its the same.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    certainly worth a read if you havnt already
                    https://www.badcaps.net/forum/showthread.php?t=22068
                      I don't think any samsung has ever used led error codes. That would make it too easy!
                      Panasonic, Sharp and Phillips do use error codes.
                      • smuddge
                        • Feb 2012
                        • 96
                        @ vinceroger69, I actually did read through that before posting. I am more confused after reading that then I was before I started.
                        I thought before I read that post it was the main board, at the end I wasn't sure anymore.
                        @ MagicSmoke, Every one of the main board alternatives is out of stock everywhere also except ebay where the going price seems to be about 120$ which is more than I am willing to spend on a tv that is worth at most 150$
                        @ mmartell, so you seem to be indicating that it is in fact the power supply that is the problem here?
                        So I guess where I am at is I have no idea what the problem is here nor which board I should be looking at.
                        Looking for some direction so I can at least narrow it down to a specific board.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4949
                          • New Zealand
                          Oops! I had the impression it was more common.
                          Sorry for the confusion, smuddge.
                          -David VanHorn
                          • smuddge
                            • Feb 2012
                            • 96
                            @ agent24 no problem any help is good help in my book
                              "I tried that and it is in fact turning on the backlight which stays on until i unplug the power." That means the inverter circuit and the power supply for the inverter circuits are OK.
                              You need to monitor the standby voltage and see if it maintain the voltage when the main board is connected. Also try disconnecting the cable between the main board and the T-CON to see if it the TV will boot with no error, but I believe you do have bad main board.
                              • smuddge
                                • Feb 2012
                                • 96
                                Will try and report back. I believe it is the main board also just don't know what part or if I could repair it rather than replace it
                                • Catman5775
                                  • Aug 2014
                                  • 6
                                  I have an LN40C630K1FXZA and it is not turning on, but when I disconnect the cable between the power board and the main board the backlite comes on, that is the only activity I get other than the red lite being on ,
                                    @Catman5775; Please start a new thread with the make and model of your TV so it will be easier to get answer for the correct model number we are working on.
                                      09-07-2024, 05:50 AM
                                    • bohaboha
                                      ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                                      by bohaboha
                                      Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                                      04-19-2025, 01:47 PM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
