Vestel 17MB12.2, IPS 32" 004B LCD panel, psychodelic picture, MDK336V tcon.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Here's an odd one....
    Vestel 32" 17MB12.2 'Accoustic Solutions' 32LCD summit or other....
    Has an IPS LCD (not seen many IPS displays) and the fault is psychodelic picture.
    Turning contrast down to around 1/8th from right down gives a reasonable (and still quite contrasty) picture.
    When I first had this set, I thought the usual--AS15 gamma chip.
    However, This set doesn't have that chip on the T-Con. I obtained from fleagay a replacement T-Con, same board exactly-- MDK336V 0 n allegedly from a Toshiba
    Fitted that--Exactly the same fault.
    Tried three different MB12.2 Mainboards, and set the correct panel make/type in Factory settings, No different.....
    Supplier reckons he had a faulty LCD, that had yellow line and this T Con was perfectly fine
    Measurements of the Vgama (called, Vcom on this board) are inconclusive, both boards compare in readings by 0.3-0.5V.
    Any ideas?
    TELEFIX
    Re: Vestel 17MB12.2, IPS 32" 004B LCD panel, psychodelic picture, MDK336V tcon.
    Can you show a picture of the fault? Best images are ones with pale skin tones.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      This video shows the fault exactly, although isn't of my set as its not here with me.
      http://www.youtube.com/watch?v=Q1bg9qP_qic
      In the vid, he does a reset on that Sams set, tried that with the vestel and also tried different panel options, no real differences
      TELEFIX
      • johndor127
        • Nov 2013
        • 10
        • Msida
        Did you repair this set because I have a set exactly with the same fault. I appreciate any help.
        • victor_cj
          • May 2015
          • 90
          Check at CN1 pin 9 Select LVDS Data Format. It is possible that you need replace software in MCU VCT7973P or eeprom 24C64.
          The art of fighting without fighting
          • Fly_Among_Stars
            VIZIO E70-E3 Half picture with half TCON
            by Fly_Among_Stars
            I have a VIZIO E70-E3.
            Symptoms: Black screen, no picture, but LED backlights are working.
            I probed the power board and voltages are as listed on the board.
            Main board appears fine, too.
            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
            There are two separate ribbon cables feeding the LCD.
            If both are connected, the screen is black.
            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
            04-24-2023, 08:20 PM
          • iglitare
            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
            by iglitare
            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
            Backlight seems to work, Sound (Setup menu after reset) works.
            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
            With my small knowledge i would think at least the cables are good.
            Can this happen because of a bad tcon board?
            Or is it always a bad/shorted...
            09-04-2025, 07:13 AM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • shelby5041
            Samsung LCD TV no picture backlight on no 12v at tcon
            by shelby5041
            hi
            i have a samsung lcd tv
            it powers on with sound and backlight but no picture
            all voltages from PS are good 12v 3.3v and 5v
            whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
            i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
            no 12v at the tcon fuse
            i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
            the odds of having 2...
            10-08-2021, 08:21 AM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
