Panasonic tc-p 50s30 sc2 sc1?
    Does anyone know if I can use an sc2 board in place of an sc1? I have a tc-p50s30 with the 7 blink error code. I purchased a new sc board and received and sc2. The tv had an sc1. I installed the board and am still receiving the 7 blinks. I have ordered new su and sd buffer boards. I'm wondering how I may be able to test sc2 compatability. Any help would be greatly appreciated thank you much
    Re: Panasonic tc-p 50s30 sc2 sc1?
    Check Q422,Q423 etc... might have received a broken board,this model it's almost ALWAYS a blown SC,due to screws not tight enough)...sc1 or sc2 as far as I know don't make a difference..
    shopjimmy has a repair kit:
    http://www.shopjimmy.com/panasonic-t...-tc-p50s30.htm
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
      Thank you much I will check that and see were it goes. Really appreciated, thank you
        correct board should be TXNSC1MNUX (TNPA5351AM), should be on a white sticker
          Yes on the sticker it is a 5351am. I was still receiving the 7 blink error code so I am installing the new sad/su boards
            Everything worked out well. I replaced my sc1 board with an sc2, still got the 7 blinks. I then replaced the sd/su boards with the ag boards with heat sinks. TV is working well, thanks for the replies and the help
            SALUTE!
