Viore lc22vh56pb
  • brian the hack
    • Aug 2014
    • 13
    Viore lc22vh56pb
    My nephew's TV is sitting on my bench-dead.
    It seems similar to 2 seconds to black except no image or sound. There is snow on the screen once it turns black, if viewed with a flashlight. It has no sound, and the power light stays green. The menu button seems to work, but not the source button as far as I can tell. I don't think it can be assumed that the main board is good, so do I need to suck it up and buy a main board for him?
    Thanks for any advice!
    Brian
  • brian the hack
    • Aug 2014
    • 13
    Re: Viore lc22vh56pb
    OOPS-UPDATE!
    I just figured how to change the source and now I have image and audio....on to the 2 seconds to black troubleshooting!!!!
    • selldoor
      Slow Learner
      • 7870
      Need a picture of the back of the power supply board.
      and the number off theside of the inverter transformers - T1 and T2
      You may find this useful start at post19
      https://www.badcaps.net/forum/showthread.php?t=10419
      When the backlight goes off does the power led stay lit?
      • brian the hack
        • Aug 2014
        • 13
        Thanks selldor!
        yes the power light stays green. I have just started on that link. "bck-19252wh 1210" is the number on t1 and t2
        • selldoor
          Slow Learner
          • 7870
          Ok First can you get a brush and brush off whatever is on the board - hasnt had a liquid spill??
          No power to the board Meter on ohms 2000 test TP6 to TP4 and TP7 and TP9
          Top corners of the board (in your back picture)
          • brian the hack
            • Aug 2014
            • 13
            it doesn't look like a spill looks like sloppy manufacturing...it doesn't wipe off.
            tp 4-6 is 620 k ohms
            tp 7-9 is 621 k ohms
            • brian the hack
              • Aug 2014
              • 13
              c5 is burnt next to t1 --- c13 next to t2 is bright blue.
              • selldoor
                Slow Learner
                • 7870
                Yes - I had just spotted that - it looks to me as though the glue they used to stick the
                lamp plugs in gas gone conductive. Carbonised then shorted possibly taking out the
                capacitor and if unlucky the transformer
                Suggest replace the capacitor and price up the transformer?
                EDIT Oh Good - just backtracked on the transformer results and it looks like its ok
                EDIT2 I am assuming you mean 620 ohms not K Ohms
                • brian the hack
                  • Aug 2014
                  • 13
                  Thanks so much!
                  I will source the cap and report back.
                  Yes, sorry .620 k ohms 620 ohms
                  • selldoor
                    Slow Learner
                    • 7870
                    While you are there there is a new thread here that we are hoping to promote to beginners
                    and I was wondering if you would give permission for that picture to be used as it covers two things to look for in one picture - off colouring and burnt glue
                    https://www.badcaps.net/forum/showthread.php?t=38391
                    You will also need to clean off the burnt glue and off the other side before it goes bad
                    • brian the hack
                      • Aug 2014
                      • 13
                      Sure that is not a problem! Thanks again for your help!
                      • brian the hack
                        • Aug 2014
                        • 13
                        Hey Selldoor, it is working! I replaced c5 and all is good for now!!
                        Thanks so much
                        Brian
                        • selldoor
                          Slow Learner
                          • 7870
                          Hey - Well done - You will be favorite uncle for a while eh
                          • ChaosLegionnaire
                            by ChaosLegionnaire
                            09-13-2022, 09:02 AM
                          • LEECH666
                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                            by LEECH666
                            Good day ladies and gentleman!
                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                            01-19-2024, 05:46 PM
                          • Christos Tsiligiannis
                            Marian Trace Alpha sound card repair help
                            by Christos Tsiligiannis
                            Hello to the forum.
                            My name is Christos, I am new to the forum here and i am posting from Greece.
                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                            11-18-2024, 05:26 AM
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-12-2024, 02:30 PM
                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
