Emerson LF320EM4 A after surge
  • Rjj22783
    • Aug 2014
    • 7
    • Usa
    Hello everyone, I have an Emerson tv that recently got damaged due to a lightning strike. It has picture and sound but I heard a buzzing sound coming from the back. i opened up the tv and traced it to a blown capacitor. now I have no expeirience with electronics, but the field had always interested me. anyway I am trying to find a replacement capacitor but ant find the values on the capacitor itself, I dont think. I hope the picture helps. Thank you in advance for any help or information.
  • selldoor
    Slow Learner
    • 7870
    Re: Emerson LF320EM4 A after surge
    The values will be on the other side. CARE when handling - set off and unplugged - even then you should test across the legs with a multimeter on volts DC 600.
    It is probably 100uf 400volts
    They are usually glued down?
    • Rjj22783
      • Aug 2014
      • 7
      • Usa
      Yes, it is glued down, any tips on removing it without damaging anything? By the way, thank you for such a quick reply and the information.
      • SteveNielsen
        Retired Tech
        • 2327
        A small amount of force prying on the non-lead end should free the cap from the glue. The only caution in that is to not damage the board with the tool used to pry it off.
        • truep
          • Aug 2010
          • 373
          Why do you think it's bad? Those rarely fail. If it's buzzing, the rectifier may have one side out Check the voltage.
          Set meter for 600V, check across the two pins. Be careful NOT to touch any of the heat sinks as they will be hot and can give a nasty shock!!
          • Rjj22783
            • Aug 2014
            • 7
            • Usa
            I should have posted a pic of the bulge in the capacitor, also leaking.
            • selldoor
              Slow Learner
              • 7870
              Hahahahahah - yes you should - at least you dont have to worry about
              damaging it - just snip the legs and it might twist off the glue.
              As it has leaked you should clean the area up with Ipa
              Also perhaps test the rectifier - in case it has been damaged.
              • Rjj22783
                • Aug 2014
                • 7
                • Usa
                got it off, labeled 200v 330 85c. any recommendations as far as where to get one? thanks to all for the help by the way.
                • SteveNielsen
                  Retired Tech
                  • 2327
                  That's a 330uF 200v general purpose cap, should be easy to find and inexpensive. I agree you should check the rectifier and also check that fuse, F602.
                  • Rjj22783
                    • Aug 2014
                    • 7
                    • Usa
                    Going to check both, it seems that there aren't really any stores that stock capacitors, looks like everything is online, lol. Does that seem about accurate?
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      Yep. Actual on the boulevard electronics parts stores are a dying business.
                      • selldoor
                        Slow Learner
                        • 7870
                        200v - must be just made for the US market.
                        Hmm there doesnt seem to be an actual rectifier on this board it is 4 diodes
                        Please can you post a good clear picture of the top and bottom of the board
                        using manage attachments jpgs less than 3mb work
                        • selldoor
                          Slow Learner
                          • 7870
                          Sorry just another thing - dont get one from ebay and dont get one from radioshack
                          • kev1n69
                            et1984
                            • Jul 2012
                            • 13
                            • usa
                            And make sure to get the 105 degree version for longevity the 85 degree is obviously not rated high enough as it vented.
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
                            • proxneo
                              Recapping Sony ICF-SW55 - verifying cap values
                              by proxneo
                              Dear reader
                              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                              At the moment, I have selected replacements based on the following list of values:
                              3 x 470uF 10VDC
                              3 x 4.7uF 35VDC
                              4 x 47uF 50VDC
                              8 x 22uF 6.3 VDC
                              1 x 220uF 6.3VDC
                              5 x 100uF 6.3VDC
                              Which...
                              06-21-2023, 12:38 AM
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:30 PM
