I have this sanyo that shows a green light when the power button is press but it only shows for a short period of time then goes out. no picture or audio comes on during this time. sometimes i can hea a click from the power supply I thing.
Sanyo DP50740 Green Light On then Off
Re: Sanyo DP50740 Green Light On then Off
pics from the boards?Proud owner of dozens of broken TV's and many,many,many boards.
Our website and passion:http://hollenhundshepherds.com/ -
hmmm....panasonic y and z boards....
Behind the mainboard(where all inputs are on) is the logic board.We need a pic from that.
You can probably unscrew bracket from mainboard without having to unplug connectors...Proud owner of dozens of broken TV's and many,many,many boards.
Our website and passion:http://hollenhundshepherds.com/Comment
Can't see a autogen spot on the logic board..I'm trying to get you to run the build in test patterns,to see what results that gives.
Try and unplug the lvds cable from the mainboard and plug tv in,anything?
Do you have a digital multimeter?Proud owner of dozens of broken TV's and many,many,many boards.
found manual on tom's database.Attached Filesif you find these attachements useful please consider making a small donation to the site
please,I need more information about that...my tv is broken.....thank armandoComment
by MOSSEPHi
Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
I have already tried replacing all of the...-
by MOSSEPHi
I have already tried replacing all of the... -
by lcdcaps1Hi
I have an 820-2610-A motherboard that has no green light.
I have noticed is when I do a SMC reset the light on the Magsafe blinks.
From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
The sys onewire circuit on this model and others is more involved
I was hoping if anyone knows about this and how it works, can reply and let me know
I know this is an old model but I am sure there are people who still works on these or knows about them
I get 1.1v on the C7771 capacitor and will replace... -
by blazzeliaHi guys,
I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating... -
by jheunnei have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
in first image there is 0v out for lcd
https://ibb.co/5XppmpkH
in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
https://ibb.co/fdJkbJs8 - Loading...
