My horror movie continues.. "70X690E Power Supply- the Sequel - Attack of the Backlight circuit!"
  • phuzzyday
    • Feb 2025
    • 11
    This was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
    (All the Electrolytics are brand new.)
    I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
    I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out which it is! If it's available obviously.. I have a backlight tester, it's working! The Mosfet on the negative rail broke in half when I tried to lift a leg, so I replaced it with a new exact match from Digikey. I scoped around enough to tell that, upon powerup, the negative side was getting PWM pulses to try the backlight circuit, then failing it. The positive side was lifting to about 250V at the same moment that the PWM test fired, but it needs at least 294 to push through the backlight array!
    So I'll ignore the previous history for a moment, and just ask, is there a resource which is specific enough to this board (70X690E Pwr) that can educate me about how its specific design of the backlight circuit can best be troubleshooted?
    Even this question.. What's the basic layout of this supply? Is the mosfet on the negative rail the switching element for the actual flyback converter? Can anyone give me a bit of a testing strategy, now that I have narrowed it down this far?! I'll send a couple pics of the LED section of the board. I'm having trouble finding the feedback resistor divider too!
    I found the datasheet of the IC below the Mosfet, it's BD9488F. That does give me a bunch of things to check in the meantime.
    Please forgive this newbie bothering you guys who are so generous with your time.. again!
Name:	Bottom Power Section (2) (Medium).jpg
ID:	3649262 Click image for larger version
Name:	Top Power Section (2) (Medium).jpg
  • phuzzyday
    • Feb 2025
    • 11
    I've been looking at the board, and discussing what I see with Claude. Does this summary from Claude seem right??
    Your Signal Path Analysis:
    High Voltage DC In: 300V+ from transformer/rectifier Through Inductor: Energy storage and current smoothing Through High-Side MOSFET: (The one on the heatsink) - this switches the current on/off Through Current Sense Resistor: Provides feedback for current regulation Through Filter Caps: Smooths the switching ripple Through LED Array: Your load Through Low-Side MOSFET: (The one you replaced) - provides the return path during the "off" time To Ground: Completes the circuit This is Synchronous Buck Operation:
    High-side MOSFET ON, Low-side OFF: Current flows through the path you described High-side MOSFET OFF, Low-side ON: Current continues flowing through the inductor via the low-side MOSFET (instead of a diode) Why Synchronous?
    At these current levels, using a MOSFET instead of a diode for the return path is much more efficient - MOSFETs have lower voltage drop than diodes when conducting. The Current Sense Resistor:
    This is key - it allows the control IC to monitor LED current and adjust the PWM duty cycle of both MOSFETs to maintain constant current regardless of LED voltage variations.
    So your failure analysis should focus on that high-side MOSFET (the heatsink one) since it's doing the main switching at 300V and high current!
    If this sounds right, I think I know what to look for !
    • phuzzyday
      • Feb 2025
      • 11
      Just got more interesting. There is only a smoothed 150V coming out of the transformer at the bottom of the pics which is feeding the LED circuit through the two outermost pins. Now I need to figure out if it's the Xformer, OR the power entering it!
      • phuzzyday
        • Feb 2025
        • 11
        THE PERILS OF IMPROPER AI USE! THE PREVIOUS TWO POSTS ARE INCORRECT. I CAN'T DELETE THEM! CAN THE MODS?
        I guess I can't edit posts. Anyway, I was wrong about that. I have a couple numbers mixed in my head, and the AI's got all confused too. They can only work with what you give them!
        So, the supply going to the LED driver circuit is at a nice 150, and it's RIGHT. I became even more sure when I realized the smoothing caps were 200V rated. I had it in my head that the LED circuit was a buck converter, since the AI told me it was, but again, I don't blame the tool if I don't know what to tell it.
        So I need to analyze the pins on the driver IC, BD9488F, and see if it is being given the right circumstances to work right. I DO know its getting PWM from the mainboard, and the circuit to the output/mosfet is fine on the negative side. That chip needs to power the boost converter Mosfet on the positive side also though, and that seems to be the issue. The good thing is that the chip costs about $1.50. Too bad shipping is $8 from Digikey. But if that's all I need, GREAT! I will be determining that tomorrow. I don't know if anyone is reading this stuff, but at least it'll be archived for future searches. The good info with the bad.
        • EazyBone
          • Jun 2023
          • 1329
          • United states
          What about this.
          https://a.aliexpress.com/_mL9tduL
          • kjchatman
            playstation 5 crashes and cuts off while trying to playback a dvd movie
            by kjchatman
            the disc drive works perfectly because i can install games with it and it can read the movies.I can never get it to playback a movie disc. it goes to a black screen and sometimes a green screen then the console shuts down. It does it every single time i try to play a movie. The games also do the same thing If I don't start them up immediately after the console boots up. I've tried factory resets and replacing the ssd controller and the southbridge but nothing has resolved the issue
            11-11-2024, 06:52 PM
          • hemant_2222
            Wharfedale Movie Star 70+ Schematic Required.
            by hemant_2222
            Hello Friends,
            Greetings!
            I have taken this active subwoofer from Wharfedale for restoration. This is already in a bad shape as far as the connections goes. It has already been worked by local technicians. The most important part that I am looking forward is the schematic diagram, as there is jumper placed and a track has been cut, as if to bypass the actual connection. I am not sure if this is by design or someone has tried something to achieve.
            Another thing is the TDA7294 was badly treated with its legs cut and it had a crack too, so I have replaced it...
            04-18-2024, 01:17 AM
          • TonyCajeta
            RX 6900 XT ED Black screen, audio continues, then crashes and fans go 100%
            by TonyCajeta
            Hi there,
            i think this could be an interesant case, got a RX 6900 XT limited edition Sapphire Toxic Liquid Cooled, i went out for a week and when i came back my graphics card was doing some weird sh¨t.
            I can use it for basics tasks, but when i run something that requieres heavy GPU power the screen goes black, audio keeps on, radiator fan at 100% then 5-10 seconds later it shuts down.
            Ok, then some weird stuff again, next time i power on it says "USB DEVICE OVER CURRENT STATUS, PC WILL SHUT DOWN IN 15 SECS"... it must be a related condition,...
            06-19-2023, 08:41 PM
          • tooko
            HP Spectre XT 13-2103ef ultrabook platform attack detected
            by tooko
            I have this HP Ultrabook bought in a second hand computers store , unfortunately it had been locked remotely , is there any method to unlock this ? The vendor claims that it is not is responsibility. I searched for solutions but I did not find anything. I have tried to dump and unlocked BIOS as it was a simple BIOS password removal but I get the same thing. Can someone give me a solution or any clue please ? I mean of course any hardware solution.
            Best regards...
            02-12-2023, 09:59 AM
          • diegito11
            Frozen screen on Asus P8P67-M PRO motherboard
            by diegito11
            good companions, I have a rare case to tell you to see where to attack.
            It turns out that I have an Asus P8P67-M PRO version 1.0 board that turns me on and gives video and I enter bios but when it comes to installing an operating system, it always hangs either in the installation or once finished, I have tried with Windows 10 and W.7, I have changed the pendrive and it continues to fail me, I have even installed a W 10 installation of a hard disk that I use on many boards to see that it works and it gives me video, just for checks and there it starts windows but After a while it crashes,...
            12-22-2021, 02:26 PM
