which is main board lg lc2d
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I got this tv its a older lcd and it tuens on but screen just blue. No sound or anything so i figure its main board but i cant determine which one of these boards is the main or please explain to me why there is two baords and what the difference is?
  • MagicSmoke
    • Feb 2011
    • 275
    Re: which is main board lg lc2d
    Looking on fleabay this appears to be main.
    http://www.ebay.com/itm/LG-part-3911...item2ed3b5ee86
      Dark blue, only faint backlight glow, or solid blue, like "No Signal" colour?
      • mattstolte
        • Dec 2013
        • 612
        • usa
        Like a faint backlight glow maybe a dark blue? But i would say its dark blackish blue with a faint glow
        • mattstolte
          • Dec 2013
          • 612
          • usa
          So which one of these would be considered main?
            Left hand one. Right hand one is just analog inputs.
            I do not think it is main board. Have you checked the fuse on the T-con board?
            • mattstolte
              • Dec 2013
              • 612
              • usa
              but tom wouldn't I have sound if it was tcon?
                Not always. In one example I had, a user had muted the TV accidentally whilst trying to get the picture back. The fault was the inverter - only - fixed that and then unmuted the sound. Also the previous owner could change the sound options in the menus for example turning off the speakers, changing audio output mode, etc. Don't rely on a single fault for troubleshooting - you need to check some things 1st.
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  fuse is good
                  • mattstolte
                    • Dec 2013
                    • 612
                    • usa
                    ok so I replaced the main board which is he one on left side. and still same thing. tv lights up but screen still black. so I got 2 other options either tcon board or is it possible its the input board on the right?? I tested fuse on tcon its good. but I imagine tcon still go bad with fuse being good. so any help guys?
                    • multimeter
                      • Jan 2011
                      • 739
                      • united kingdom
                      what voltage are you getting on the t-CON fuse,using black probe to cold ground red to fuse?
                      any visable faint picture using a strong light?
                      tried re-seating LVDS cable?at both ends.
                      do you see backlights through the holes in the rear of the panel with lights off?
                      voltages ok on power supply?
                      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                      • mattstolte
                        • Dec 2013
                        • 612
                        • usa
                        yes backlight is on the whole time. I resetted lvds cable both ends. its just backlights no picture
                          I think you should check AVDD, VGH, VGL and 3V3/VDD/VCC on the T-con board, there should be test points. I do not think the analog board can cause the issues you are having.
                          • ygorsan
                            by ygorsan
                            🧩 Problem Summary:
                            • I
                            07-28-2025, 08:34 AM
                          • jb_Bak
                            by jb_Bak
                            CN6401
                            Pin 01 NC
                            Pin 02 NC
                            Pin 03 "BL_ON": 0V
                            Pin 04 "N/C"
                            Pin 05 "STBY 3.3V": 3.5V
                            Pin 06 "GND": N/C
                            Pin 07 "AC_OFF"...
                            09-27-2021, 04:52 PM
                          • JDC
                            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                            by JDC
                            ONN 100012588
                            Issue: No Power, Then Rebooting After Main Board Change
                            Short answer: replace main board and power board
                            Technical answer: replace main board and Q306 & Q307 on power board.
                            Long answer:
                            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                            07-15-2022, 07:39 AM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
