Vizio E320i-B2 powers with logo then shuts off
  • phil@philporter.com
    • May 2013
    • 113
    Vizio E320i-B2 took an indirect lightning hit the other night. Now it will power up with the Vizio "V" logo on the screen and then turn back off. Can not see any bubbled caps. Are chances good it is a power supply issue. Found them for about $20 on EBay - would it be easiest to purchase the entire board?
    Do the symptoms of powering on then off point at all to the main board? Thanks
  • JaquesPratt
    Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
    by JaquesPratt
    I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
    This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
    07-16-2024, 01:04 AM
  • ossroy
    Vizio M60-C3 powers on, perfect logo, turns off
    by ossroy
    Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
    My kids are getting antsy waiting...
    08-03-2022, 08:11 PM
  • Super360
    Vizio E701i-A3 Vizio logo flashing then turns off
    by Super360
    Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
    07-25-2024, 07:06 PM
  • lowpost99@gmail.com
    Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
    by lowpost99@gmail.com
    I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
    09-03-2024, 02:57 PM
  • csmith
    Vizio D50u-D1 Powers up no picture
    by csmith
    I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
    Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
    supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
    issue. Set will power up with remote but not power off....
    07-11-2025, 11:52 AM
