Samsung UE46B6000VWXXC - Vertical Lines
  • angelicous
    • Jul 2014
    • 31
    • Portugal
    Hi there guys, my samsung is giving me problems with vertical lines right in the midle of the screen, and it covers both sides. It's not the entire screen it's probably 30%, but it's like 20% one side, 10% the other side.
    I've opened the panel, try to power it on to see if there was a problem with the ribbon cables on the T-com, but no result... But i noticed a "click" sound when i tuned it on on the power supply. TV takes some seconds now to turn on, and it keeps making the noise, then when on, this "click" stops, and the TV has this vertical lines. The click sound will be back when i turn off the TV.
    So i took the power supply of the TV, turned it on alone(only the power suply conected) and that "click" sound never stops. I don't know exacly where it comes from, so i removed the capacitors that where closer to the sound to test, and they all charged and discharged ok with the multimeter, and i turned the TV on(without the capacitors) to see what it does without them and immediately blew up a chip.
    I don't know what this chip is or if it was causing the problem, but it blew up. I turned the board on again with the capacitors on the board now, and it doesn't do any sound now.
    How can i know what that was? Board is a PSLF171B01B, and the chips has written ICB801
    Here is a pic of the board and what IC blew up.
    It like ripped the top off, i have like half of the IC, but it doesn't help very much i guess... It has 3 lines. I can read:
    BR0665J
    G0916
    7167C4
    Can someone help?
    • 31199
    Re: Samsung UE46B6000VWXXC - Vertical Lines
    infineon psu chip
    ICE3BR0665J
    • angelicous
      • Jul 2014
      • 31
      • Portugal
      Thanks stj.
      Could this IC be the cause of the problem? Or me taking the capacitors out just blew up the IC?
      • stejones
        • Apr 2012
        • 55
        Hi i have one of these power board can anyone help its just dead i have replaced it now but would like to know wat as caused the problem all the caps look to be ok and all fuses
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          Sadly it has vertical lines at the left and one line in the middle-right.
          I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
          I have factory resetted the TV as well but also with no luck.
          I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • arctor
          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
          by arctor
          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
          04-26-2025, 05:22 AM
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • x_orange90_x
          Samsung UN46C8000XFXZA vertical bars/horizontal lines
          by x_orange90_x
          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
          09-04-2023, 12:09 PM
        • polaro
          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
          by polaro
          Greetings,
          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
          08-27-2022, 08:46 AM
