sylvania lc40ss8 won't power on
  • thatkid8520
    • Jul 2014
    • 13
    • United States of America
    I have a 42 in. sylvania lc40ss8 that was recently given to me that won't power on.
    When plugged in it emits a high pitched whine from what appears to be a transformer marked T600 which changes when the power switch is pressed.
    I see no evidence of a blown component
    Here's a link to the service manual
    • 31286
    Re: sylvania lc40ss8 won't power on
    sounds like something shorted - maybe a diode.
    • thatkid8520
      • Jul 2014
      • 13
      How would I go about checking that?
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        Do you have a digital multimeter?
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • thatkid8520
          • Jul 2014
          • 13
          No, I have the world's cheapest analog multimeter though. Will that do?
            It is difficult to repair modern electronics with only an analog multimeter, they usually do not have the resolution necessary to pick up small changes in voltages which can be critical to operation of a TV.
            • thatkid8520
              • Jul 2014
              • 13
              Is there a way to at least check a few diodes with an analog meter?
              • johnboy1313
                • Nov 2012
                • 1959
                You can get a capable digital meter from Harbor Freight for $5.
                • thatkid8520
                  • Jul 2014
                  • 13
                  I tried testing the diodes by putting my multimeter in the resistance setting and checking the diodes in each polarity.
                  All of the large diodes surrounding the transformer are showing a short in each polarity, could that mean the transformer itself is busted?
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    Transformers barely ever die...
                    It is most likely your anolog meter,you really can't use it for tv repair...
                    Do yourself a favor and get a cheap digital multimeter,you can get them for a couple of bucks,small investment but well worth it once your tv works again
                    In general you can test diodes on the board,sometimes you need to desolder one leg,to read it out of circuit...
                    • thatkid8520
                      • Jul 2014
                      • 13
                      That leads to another problem, it's a leadfree board. I need to keep soldering to an absolute minimum
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        Why?
                        • thatkid8520
                          • Jul 2014
                          • 13
                          Why?
                          I've never soldered with leadfree and I'm not sure if my iron will even work with it.
                            No need to use leadfree, you just add regular solder to the joints.
                            • thatkid8520
                              • Jul 2014
                              • 13
                              Is there a trick to getting the original components off? Sorry if I'm asking stupid questions I'm really new to this.
                              • martino
                                Not so "senior"
                                • Aug 2013
                                • 997
                                • canada
                                You might find sometimes that leadfree solder is hard to "melt",simply ad a bit of normal solder to it as you heat the pad,it will mix and you will find it melts easier that way...
                                  What tools do you have for removing solder off the board?
                                  • thatkid8520
                                    • Jul 2014
                                    • 13
                                    A weller 8200 soldering gun and some soldering braid.
                                      Soldering braid and solder flux are good to use together for removing the old solder. Flux is good to have when you do soldering works. The 8200 is not practical for PCB works you are more likely ending up damaging the the solder pads and traces.
                                      • thatkid8520
                                        • Jul 2014
                                        • 13
                                        Will it at least be possible if I move quick enough? I don't have enough money to buy a new iron.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
