Olevia 747-B11 Dark screen, No sound
  • TCB
    • Jul 2014
    • 8
    Hi. I'm new here.
    I recently was given an Olevia 747-b11 47" LCD TV (very heavy object)
    Symptoms: When powered up has dark screen, no sound.
    Am told problem originally occurred when TV was operated one day for many hours in very high ambient temperature (Florida, summer, A/C broke down)
    Details:
    When Plugged in and main power switch on, blue pilot light appears.
    When TV is POWERED UP, Blue pilot light goes out, a click is heard, a brief 'chirp' is (sometimes) heard coming from inside the TV, no activity, dark screen, no sound.
    Observations:
    When powered down, D1 LED is RED.
    When powered up, Main PCB has many GREEN LEDs,
    2 RED LEDs (D1, D2 RED)
    and 1 LED comes on briefly as GREEN (D96) then goes dark, sometimes with a high pitched chirp sound coming from main PBC in this area as the protection circuit shuts the set down. The LCD backlight never comes on even for a second.
    24VDC observed at both TCON boards with VM.
    Fuses (8 on each) TCON board test ok (tested in circuit with ohmmeter)
    Shielding removed to reveal TCON boards, Main PCB, Power supply PCB.
    No visibly bad caps on any of the above PCBs.
    PCB IDs / numbers:
    MAIN PCB
    DigiMedia Technology
    SDA1 R0.9
    PCB P/N EPC-P508201G000
    STICKER P/N sc0-p5028201-s10 NS1
    STICKER S/N CSHN7B01202355
    POWER SUPPLY PCB
    Delta
    DPS-408AP B
    Rev S3-F
    S/N A16W0742049708
    TCON PCB - left
    CMO S
    4H.V1838.351 / E2
    VK8A183L02 0735TD-S11172
    27-D005130 1470H1-24-V01-D1H0 REV 1H
    TCON PCB right
    All numbers exactly same as above EXCEPT is M11172 instead of S11172
    Anyone know what other model badges this TV might appear as? parts interchanges for PCBs?
    Help?
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Olevia 747-B11 Dark screen, No sound
    I would start by posting some clear pictures of the boards and back of tv as a whole...
    That way the expert here can help you a lot better....
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • TCB
      • Jul 2014
      • 8
      Hi!
      Thanks for the suggestion.
      Will take and post pics later tonight.
      I will add that my TV appears to be identical in appearance to the unit pictured elsewhere in this thread.
      TCB
      • mmartell
        • Oct 2013
        • 3189
        Elsewhere in what thread ?
        • TCB
          • Jul 2014
          • 8
          my bad. There is a previous thread someone posted on this a long time ago (Found this site via that thread via a google search)
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • Rozp
            70LE660U dark cloud or black screen with sound.
            by Rozp
            Hello Everyone,
            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
            08-29-2023, 05:25 PM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
