LG 50PA5500 Plasma - No picture then no sound
    Re: LG 50PA5500 Plasma - No picture then no sound
    Check your Y-buffer board for shorts:
    https://www.youtube.com/watch?v=51SZsfH60EY
    • Solomonj151
      • Sep 2015
      Originally posted by tom66
      Having dealt with one of these myself...
      Disconnect the top Y-buffer board. It's the board in the top left of the panel with the orange ribbons coming out of it. You will need to undo the ribbons and unscrew the board, then slide the board out from the connectors.
      Turn the TV on, if you get half a picture, the plasma panel is bad and this is an unrepairable fault. There is a serious design flaw with these panels where the casing eats into the ribbons going to the panel causing short circuits. Unfortunately the ribbons aren't replaceable, they are glued to the panel.
      Hello, I have a similar issue, LG 50PA4500. This is my first "in-home" TV repair, I have some experience with a previous employer swapping boards for computers / TVs but do not understand the technical jargon of how electrical current works. I have basic multi-meter skills but if you can help me in any way I would appreciate some coaching here.
      My TV was working fine this morning then all the sudden it turned off. I thought this was because of my computer screen saver but when I tried to use the remote to power on there was no video. After a few times of trying to power it on I realized a few things.
      Probing:
      - With the TV unplugged, I plugged it in and heard the click like normal.
      - Then pressed the power button on the control panel, it clicked again like normal.
      - The power light (red) flashed twice (unusual)
      - No video appears from my live HDMI source, I confirmed that there is sound coming from the source through the TV.
      Troubleshooting:
      - Took off the back casing, there are no bad caps.
      - No evidence of burning or overheated components
      - No smell
      - No unusual noises
      - The red light on the main board is solid
      - The green light on the control board is flashing
      - I tested the VS and VA on all 3 power boards and the voltage was normal.
      - After looking through several forums I followed the steps of removing the top left Y board like the screen shots that Mac108 posted.
      - I powered on the TV and the bottom half flashed grey briefly and then disappeared.
      - Does this really mean that my display is shot because of the ribbon cables? Is there any other troubleshooting that I have overlooked? I found most of the boards on shopjimmy...
      • Solomonj151
        • Sep 2015
        Also I might add after the bottom half flashed grey, I noticed that the backlight is consistent across the screen but there is still no video from the input source.
        - When I put that Y board back in, I have no backlight and no bottom half flash upon power on.
        • Solomonj151
          • Sep 2015
          After pulling the top left Y Board in the 50PA4500 I did a continuity for shorts like Tom66 linked, I found that on the bottom ribbon connector there was one area at the end which made beeps for what I am assuming is a short? Any help would be much appreciated.
          • Solomonj151
            • Sep 2015
            I know no one responded to my messages but I FIXED IT!!! If anyone stumbles across the post in need:
            - After ordering the suspected top left Y board EBR73748601 Buffer Board EAX64299201
            - I installed it and the TV worked perfectly.
            - I did find upon initial inspection that the "ribbon pinch" issue did occur on my TV, the ribbon cable connected to the board did have a cosmetic issue that may have been the original cause. I am unsure. I moved the TV 1 day before the issue began, set it up and it worked fine until the next morning, then the issue occured.
            - By replacing the EBR73748601 in my LG Plasma 50PA4500 the issue resolved.
            - see the pictures below of the actual board and ribbon cable referenced in my solution message above.
            • freakaftr8
              • Oct 2012
              • 3743
              Originally posted by Alastair E
              Freaker8--
              Does that bad tab/plastic case issue happen on the smaller, say--42" versions of this series....?
              sorry I missed your post to answer your question I'm honestly not too sure I only encountered the 50 inch version of this tv
              • freakaftr8
                • Oct 2012
                • 3743
                Good glad to hear it's fixed now for some preventative maintenance I would remove those little plastic tabs that rub the ribbon cables because it is going to cause a problem it's not if its when.
                • Alexdjx
                  • Nov 2019
                  • România
                  #68
                  Somebody helps me with a leg pa5500 no video and sound??
                  • KYBOSH
                    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                    by KYBOSH
                    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                    No picture but you hear the TV static (white noise) playing loud and clear.
                    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                    But it seems they didn't get too far and just left it.
                    When I first took a look I was amazed at how pristine the inside looked.
                    Its as if the TV had been in a time capsule.
                    Caps looked like they were just pulled off the self.
                    Copper coils had no sign of corrosion on...
                    02-01-2023, 11:10 PM
                  • divingfe
                    LG Plasma 50PA5500. Sound, no picture !!
                    by divingfe
                    Sorry if this is too repetitive, or in the wrong place.
                    I'm new, and having much the same problem. My LG50PA5500 TV has been working flawlessly since new. The other day, while in the midst of watching a broadcast DTV channel, the entire screen suddenly and silently went dark (no snaps, crackles or pops); sound, channel selection and inputs all work OK.
                    I have checked connections and voltages from: stdby, pwr supply board fuses, psb output voltages to Zsus board and its fuse, output voltages from Zsus to Ysus and its fuse. All precisely normal!! I've also checked voltages to the...
                    06-19-2021, 06:36 PM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
