Faulty lg 50pg3000
    Re: Faulty lg 50pg3000
    OK, place the red probe on the copper area marked in red. Then run the black probe along the ribbon connector contacts. Try not to miss any.
    Your meter should be on the beep mode - i.e. when you touch the probes together it should beep.
    You only need to do this on the upper buffer board. The lower is OK.
    • scootmansfield
      • Jul 2014
      • 28
      So am I looking for continuity across all contacts?
        You should get no continuity.
        I am fairly sure your top buffer is bad, but this is additional information which will confirm it.
        • scootmansfield
          • Jul 2014
          • 28
          On the left set of terminals there was no continuity but some terminals when tested gave a 1 on my multimeter and some gave varying numbers 476 589 etc.
            OK, that is a bad board. They are not dead short but they are leaky. So I would say you can just go and replace the top buffer board to fix this problem.
            • scootmansfield
              • Jul 2014
              • 28
              Middle ribbon connector contacts all gave varying numbered readings and not one 1 reading
              • scootmansfield
                • Jul 2014
                • 28
                The left hand ribbon connector is right where the lines are horizontally on the TV as well does that make sense?
                  Can you try reversing the red and black probes and do the test again?
                  • scootmansfield
                    • Jul 2014
                    • 28
                    Just a constant 1 when I do that
                      Hm, no shorts. Well, I would say replace the board anyway, given the fault symptoms. I can't see any other part causing it. Wish I could be more conclusive, though.
                      • scootmansfield
                        • Jul 2014
                        • 28
                        Ok Thank you
                        Where is the best place to buy one from?
                        Any ideas?
                          eBay, FlatTVParts, RecyclingLives, ...
                          There are many, but getting the part may be tricky.
                          There is an LG distributor selling a new part for about £70 all in.
                          • scootmansfield
                            • Jul 2014
                            • 28
                            Where is the new part 70 quid is ok? I will buy today
                            • scootmansfield
                              • Jul 2014
                              • 28
                              Recyclinglives coming up bad domain
                                Just search for your EBR number printed on the sticker.
                                e.g. EBR123456789
                                • scootmansfield
                                  • Jul 2014
                                  • 28
                                  Hi Tom is an EBR50039008 the same as my EBR50039005?
                                  Been offered one on ebay
                                  http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    #37
                                    Be careful the guy who's listing that tv has a cracked screen which sometimes shorts the buffers etc I've learnt my lesson buying cracked screened tvs
                                      If the Y-sustain and control board have the same part numbers it should work OK.
                                      Sordids is correct it can cause issues though I am not aware of it affecting LG, only Samsung and Panasonic, you will be taking a risk...
                                      • scootmansfield
                                        • Jul 2014
                                        • 28
                                        Just to let you know TOM that part I purchased from Ebay worked fine!
                                        Many thanks for your expert advice
                                        • JarzabekPZ
                                          HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
                                          by JarzabekPZ
                                          I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
                                          08-08-2025, 03:40 AM
                                        • Spudgun
                                          Why doesn't current just bypass faulty capacitors.
                                          by Spudgun
                                          Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                                          04-01-2025, 10:33 AM
                                        • b-slayer
                                          Acer A317-53 need help to disable faulty onboard ram
                                          by b-slayer
                                          Hello.
                                          I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                                          - first one is to modify le bios to disable the onboard ram.
                                          - second one is to disable the onboard ram by desoldering some components on the mainboard.
                                          so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                                          so i found that my motherboard...
                                          10-12-2024, 03:46 AM
                                        • brispuss
                                          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                          by brispuss
                                          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                          12-28-2022, 02:58 AM
                                        • nrj1982
                                          Lenovo Ideapad3 NM-C821 faulty motherboard
                                          by nrj1982
                                          Hello all,
                                          I have a Lenovo Ideapad3 laptop, that has recently stopped working. When pressing the power button, the led is going on, but nothing else is happening.
                                          I have checked the 3.3V, 5V and 20V - all of them seem present (checked with multimeter and oscilloscope in order to verify that they are stable).
                                          I have checked the voltages around PU1901 - 0.9V, 1.8V, 5V, 2.5v, 0.6V and 1.2V - all of them are present.
                                          Now going further in the debug, I found that the CPU voltages produced by RT3662AC (PU5901) PWM driver are missing. I can see that the 20V...
                                          10-04-2025, 10:08 AM
