Lenovo Ideapad3 NM-C821 faulty motherboard
  • nrj1982
    • Nov 2021
    • 6
    • Bulgaria
    Hello all,
    I have a Lenovo Ideapad3 laptop, that has recently stopped working. When pressing the power button, the led is going on, but nothing else is happening.
    I have checked the 3.3V, 5V and 20V - all of them seem present (checked with multimeter and oscilloscope in order to verify that they are stable).
    I have checked the voltages around PU1901 - 0.9V, 1.8V, 5V, 2.5v, 0.6V and 1.2V - all of them are present.
    Now going further in the debug, I found that the CPU voltages produced by RT3662AC (PU5901) PWM driver are missing. I can see that the 20V are present on PQ5901.
    Now I have tested the procedure described in the RT3662AC datasheet, where we have:
    Click image for larger version  Name:	image.png Views:	0 Size:	29.9 KB ID:	3738916
    I can see the pulse on the EN pin, and the VDD, but PGOOD remains 0, and of course the UGATE is also 0. That is why I am starting to think that the RT3662AC is faulty.
    Do you think that there is something else that I can test, before trying to replace the IC? The 0.8Vref from the RT3662AC are present, but looking at the datasheet diagram, this voltage is produced from another part of the IC.
    Thanks in advance,
    Mitko
  • nrj1982
    • Nov 2021
    • 6
    • Bulgaria
    Some update:
    - I saw that there is a very low impedance between the drain and source of PQ5905 (and all MOSFETs connected between the VDDC and GND), around 2.1 ohms.
    1. Removed the RT3662AC - still the short is present;
    2. Removed all MOSFETs (PQ5902, PQ5903, PQ5905, PQ5906, PQ5908), the short is still present;
    Is it possible that the CPU is dead?
    Thanks,
    Mitko
    • reformatt
      • Feb 2020
      • 1541
      2 ohms seems ok to me. What about VDDCR_SOC voltage? That needs to be there first as your main Vcore rails are under control of the APU via the SVID interface.
      Lenovo's usually suffer bad balls under the CPU due to the poor quality solder they use. If the fault occurred without any liquid damage or corrosion, this would be my first suspect.
      • nrj1982
        • Nov 2021
        • 6
        • Bulgaria
        Hi reformatt,
        In fact, there is no liquid damage or corrosion. Initially I have started looking for something death, because when I opened the laptop, there were two screws, free rolling over the motherboard, so I was thinking that they made some king of a short. Those two guys were coming from the SSD support.
        I can not check the VDDCR_SOC voltage for the moment, because I have removed couple of components (including the RT3662AC), but during the weenkend I will try to add them back. I will keep the post updated with this.
        Regarding the Lenovo BGA problem, now I am starting to thing that I am facing exactly the same issue, and I suppose that this will end with the very same problem, but let's first check all the other possibilities.
        Thanks you for the help.
        Mitko
        • ferah831208
          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
          by ferah831208
          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
          03-18-2025, 01:18 AM
        • air_chair256
          Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
          by air_chair256
          I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
          Tried to reball RAM 1,2,3,4
          Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
          02-13-2024, 06:00 AM
        • AYsys
          Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
          by AYsys
          Hello dear forum members,
          I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
          I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
          Nothing was flashed here — the BIOS was only backed up.
          I created the backup using a CH341A Black programmer and NeoProgrammer....
          09-13-2025, 11:05 AM
          Lenovo 3000 Series Schematic
          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
          3000 C100 laptop with Braille keyboard
          Lenovo 3000 C
          C100, C200 - 15-inch XGA screen
          Lenovo 3000 N
          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
          N500 - 15.4 inch screen.
          Lenovo 3000 V
          V100, V200 - 12.1-inch WXGA models
          Lenovo 3000 G
          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
          10-04-2024, 06:05 AM
          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
          09-06-2024, 06:40 AM
