Samsung One Connect SOC8002BB
  • Amraks
    • Nov 2011
    • 725
    HI there,
    I am working on a Samsung One Connect Box Model SOC8002BB,
    Fault happened in a sudden power cut.
    SMPS MODEL: 65Q900B/75Q800B THL1B4401176AAM5RT1C0836
    I have narrowed down a shorted Mosfet on the power board QM953CS.
    Its a KEC KU 210N20P I am having no luck finding these at all replace.
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Verify the markings on the mosfet is correct.
    You maybe misreading it.
    Post a clear pic so we can help.
    • EazyBone
      • Jun 2023
      • 1342
      • United states
      Was the fuse blown?
      • Amraks
        • Nov 2011
        • 725
        This was verified under a microscope exactly what was writing on these mosfets
        • Amraks
          • Nov 2011
          • 725
          Originally posted by EazyBone
          Was the fuse blown?
          No fuses blown at all.
          • EazyBone
            • Jun 2023
            • 1342
            • United states
            https://alltransistors.com/mosfet/tr...ransistor=8375
            Maybe this?
            • lotas
              • Jan 2016
              • 4616
              • Russia
              KU210N20PS1
              https://www.keccorp.com/en/product/p...ew.asp?idx=727
              • Amraks
                • Nov 2011
                • 725
                Ok I have found a substitute I will replace all 4.
                https://www.digikey.com.au/en/produc...3206PBF/811613
                Looking at the rest of circuit I can not find any other issues. would I be safe to assume this is all that blew.
                • Amraks
                  • Nov 2011
                  • 725
                  Just realized that's the wrong package anyone have any suggestions on what I should use or have any contacts to get keccorp to supply these
                    09-07-2024, 05:50 AM
                  • KYBOSH
                    Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                    by KYBOSH
                    I picked this one up today.
                    Previous owner says no signs of life.
                    TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                    Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                    The TV model is QN65LS03BAFXZA - version: CB06
                    The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                    I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                    Will keep you all...
                    04-05-2025, 08:32 PM
                  • atkallu
                    Samsung One Connect Box SOC1001N vs SOC1004N
                    by atkallu
                    I am asking have somebody information about Samsung one Connect boxes compatibility ?
                    So, can I use SOC1001N box on the TV which have SOC1004N box, is it compatible ?
                    SOC1001N box has been worked with Samsung QE55Q8 and the SOC1004N box has been used with Samsung QE55Q9.
                    Boxes part numbers are the same: BN68-08730A-00.
                    07-09-2025, 01:54 PM
                  • An-klamm
                    Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                    by An-klamm
                    Hello!
                    I have a TV that I can't get any further with.
                    It is a Samsung UE 55HU8590 with one connect box.
                    When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                    As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                    Since the TV works without ocb, I assume that it can't be the PSU?!
                    I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                    Is there...
                    12-04-2023, 01:35 AM
                  • AlexVG
                    SAMSUNG UE65HU8500 ONE CONNECT pinout connector request
                    by AlexVG
                    I came across with
                    SAMSUNG UE65HU8500
                    ONE CONNECT BN41-02135
                    Chassis GOLF_UHD_1MP_JACK
                    TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
                    Moreover, on the main is written A5V. However, cable connected this pin to the GND.
                    Maybe somebody have an experience with the same issues?
                    I need your help.
                    Thank you....
                    06-08-2025, 06:49 AM
