Samsung UN46B7000 sweet scanlines bro!
  • Shinju
    • Mar 2014
    • 1239
    So I got this unit and while it turns on no problem the picture was all jacked up.
    About 5-6 minutes of letting it sit with a movie playing I hit the menu button and saw that it was on dynamic and switch it and I don't know if it was random coincidence or what, but when I selected Standard the picture when from crap (distortion, some to whoa decent! ( hence the scanlines joke).
    Now the screen has faint noticeable lines on it, more noticeable on the left then the right and at viewing distance you cannot really even tell.
    I tried the usual tap the screen, flex the bezel (this panel is super thin) and no change, I also left it off over night and when I fired it back up it looked like it did after the first picture you see. OSD is also affected too by these "scanline" deals, the first picture shows the OSD not being affected by the dotted lines going vertical.
    I have seen panel tab bond faults and this looks different, I am going to pull the back off and do the T-con/LVDS stuff and get voltage reading as well.
    Here are some photos!
    First boot up, 5-8 minutes of this and then it was gone and hasn't come back yet. (will try tonight as I have it unplugged)
    Panel looks ok but what are these lines!?
    Extreme close up!
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Samsung UN46B7000 sweet scanlines bro!
    Please can you edit your post and take the inline hosted elsewhere pictures off and repost them using manage attachments so that they remain available in the future as a help to others.
    • Shinju
      • Mar 2014
      • 1239
      fixed, I left the big ones too.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        I'm following this for an answer....Do those line go all the way from the left to the right or they fade away towards the right? (got a 55" panny doing this)
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • Shinju
          • Mar 2014
          • 1239
          I think they do go across but they are very very very faint on the right side and only noticeable when up-close on a white scene. (EDIT) I did zoom the photo up with Megan Fox and I didn't see any I will snap photo with a solid color screen to be sure.) They almost seem to stop at the end of the OSD boarder.
          I left it on for several hours and it looks the same.
          Like I said, I flexed the panel pretty hard this unit is super thin and nothing change/flickered or anything.
            I've got one doing this. It's hidden if you turn the brightness down. I'm not sure what causes it. Mine is a 40" A656
            • Shinju
              • Mar 2014
              • 1239
              heh if they were closer together and uniform I would be ok with it, scanlines look slick on video games and this panel supports my XRGB-2 unit.
              I have it calibrated with C-nets test calibration the picture on this unit looks damn good for a LED, minus the defect with the lines of course it passed my Avatar and Batman Dark Knight tests
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                On mine,I replaced the mainboard already(had other problems too) and it did not solve those lines,there is a tcon in the mail today that I will try...tried flexing screen etc too..
                will let you know if tcon solved it,if not, Im accepting a "bad panel" answer....
                • Shinju
                  • Mar 2014
                  • 1239
                  That would be awesome, update here I don't mind thead hijack.
                  • Shinju
                    • Mar 2014
                    • 1239
                    Ok,
                    So today it didn't want to bounce out of this funky mode so I broke it down to panel level to see the tab bonds, I took a toothpick and rubbed each of them and no change, if the scree. Is darker these rainbow dotted lines start to fade out, if the scenes are bright these shadow rainbow lines come back and stick around.
                    Touching the t-con to tab bond board bonds didn't change anything either, unplugging the left or right side only voided the picture per side that was unplugged. The side working still had scan lines and discoloration ect.
                    Photos inc later on.
                      My suspicion is the fault is panel level.
                      It only occurs on mine with any pixel brighter than about 230/255 RGB. Otherwise, it doesn't occur and the picture is pretty good. My suspicion is it is panel drift due to damage - UV or heat (I'm not sure.) As the panel ages the gate threshold changes requiring different drive voltages. Like a plasma!
                      One way to fix this is lower AVDD - will require modifying the T-con board.
                      Another way is to increase VGL (the turn off voltage) - I am not sure if this is possible on these T-cons.
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        Well,as promised but heavily delayed,I'm reporting back on replacing the T-con board.....
                        Didn't change a thing,still the same lines
                        I'm accepting a "bad panel" verdict........
                        Tom66,you're saying lowering the AVDD? Would you mind elaborating on this?
                        I'm game to try it ...Should I start a new thread for the experiment?
                          It will involve some fairly intricate surface mount soldering and a lot of experimentation if you're willing to try.
                          • martino
                            Not so "senior"
                            • Aug 2013
                            • 997
                            • canada
                            let's see,i got 2 T-con boards,a "bad panel" verdict and a whole lot to learn..What could go wrong,lol
                            As long as it doesn't involve lifting a IC with 1136 legs,as I lack the equipment and knowledge to tackle those...If it fails,it fails,tv was free and I'm sure I can handle a dent in my ego if things go
                              OK, post a picture of your T-con, making it clear enough to see AVDD, VGH, and VGL test points.
                              • Shinju
                                • Mar 2014
                                • 1239
                                Feel free to use this thread. I know mine is bad if I had the extra funds to toss at another t-con to try I would,but for now it's on the recycle pile!
                                • martino
                                  Not so "senior"
                                  • Aug 2013
                                  • 997
                                  • canada
                                  Couldn't get a clear enough pic,so stole one from SJ..I checked and it's identical.
                                  -VGH and VGL I circled.
                                  -Couldn't find AVDD? It has a HVDD and a VDD.
                                  • Shinju
                                    • Mar 2014
                                    • 1239
                                    that one looks totally different then the one I have installed on mine. The T-con on this panel is massive, almost the size of a small mainboard.
                                    http://www.ebay.com/itm/Samsung-Tcon...item3f3941abf3
                                      ...your Samsung TV has an LG panel? You sure about that?
                                      BTW on Samsung, VGL = VOFFE / VOFF, VGH = VONE / VON
                                      • Shinju
                                        • Mar 2014
                                        • 1239
                                        FYI, I also did the Test patterns on this one as well and they failed, the DDR ones like the other Sammy I have posted did not show up as well.
                                        When running the test patterns that would work the screen was still bleeding/ghosting and the lines were still present and disappear/reappear.
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          Sadly it has vertical lines at the left and one line in the middle-right.
                                          I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                                          I have factory resetted the TV as well but also with no luck.
                                          I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                                          A similar issue has been posted as well but also with no actual response ...
                                          Yesterday, 04:19 AM
