philips 32pfl5522d/05 cant get sam menu. please help
  • shaunbt123
    • Nov 2012
    • 119
    • uk
    can someone please help me out,i am trying to get to the sam menu of the above tv to clear the eeprom ,,i have tried as the service manual says go into analogue mode then press 062596 then press info button ,but nothing happens.
    i have the tv hooked up to another tv through scart lead as i dont have any picture on the philips tv.
    LCD LED TV Service Menu Codes
    TCL LED TV Service Menu Code
    LG LED TV Service Menu Code
    10-31-2024, 03:58 AM
  • Ierwin
    Philips 58PUS7805 Menu working but no/weird picture from video sources
    by Ierwin
    I got a 58pus7805 that shows some weird behavior.
    The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
    However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
    I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
    I managed to install the latest official firmware by holding the control button while plugging...
    03-10-2024, 12:50 PM
  • tuner2000i
    Philips 65PUS8518/12 distorted image after main board replacement
    by tuner2000i
    hello everyone,
    I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
    The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
    07-15-2025, 01:15 PM
  • Retro140
    Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
    by Retro140
    So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
    To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
    06-18-2023, 06:13 PM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
