pdp42v18ha - Turns on, no picture, no response from buttons
  • echodreamz
    • Jul 2014
    • 20
    I have a pdp42v18ha (Viore) that powers up, the screen brightens enough to show it "works", I get some red sprinkles in the upper area of the TV. However the TV once powered on does not respond to input buttons, IE wont power off, wont change input, wont change channel, no menu etc. I have to pull the power to get it to turn off.
    If I leave it on for ~20 minutes or so, I eventually get a bright blue picture (on channel 60). After another few minutes, the screen goes dark, I hear a relay click a few times and the process repeats.
    I was told by a local repair shop that the main board is most likely bad (due to the TV not responding to button commands). Just trying to get some second opinions before I buy the board. I also removed the power to the sustain boards, the TV powers on, but I still cannot turn it off by the power button.
    I checked all the caps on the board (visually), none are bulging or popped, they all look good.
    Thank you all!
  • lookimback
    • Aug 2013
    • 1489
    Re: pdp42v18ha - Turns on, no picture, no response from buttons
    Any luck with this? I have one doing the same thing. But, if I unplug mine, then plug it back in, it will work fine.
    ------------signature starts here------------
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      bad mainboard, in both cases.
      Follow the white rabbit.
      • lookimback
        • Aug 2013
        • 1489
        I was thinking that too. Could it be a bad MOSFET on the main? Or bad caps?
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          to me, it sounds like the BGA on the CPU has failed. reball or replace is the two ways to fix that. i could be wrong, budm might say something else.
          • lookimback
            • Aug 2013
            • 1489
            But if I unplug it, and plug it back in, it works fine. The issue only seems to appear if it's been off for several hours.
            • lookimback
              • Aug 2013
              • 1489
              I bought another TV from a guy 2 days ago, and he turned out to be the original owner of this one. Evidently I bought this from his cousin. Well, according to him, it's been doing this for a couple years.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                ^ in your case it may be dried up caps then.....
                • lookimback
                  • Aug 2013
                  • 1489
                  I'll pull the main and check the caps for high ESR later.
                  • lookimback
                    • Aug 2013
                    • 1489
                    I'll try freeze spray on all the ICs when it's on. Maybe something isn't making contact when it's cold, but is OK after it's warmed up and expanded. I suppose that could be a BGA issue.
                    • lookimback
                      • Aug 2013
                      • 1489
                      Haven't had much time lately but I pulled the main board and did find 2 bad caps. Haven't checked the rest for high ESR yet.
                      • echodreamz
                        • Jul 2014
                        • 20
                        Mine turned out to be a bad mainboard. $25 on ebay and walla TV came right up.
                        • lookimback
                          • Aug 2013
                          • 1489
                          I replaced those 2 bad caps and I think it's ok now. It comes right on without a problem. ESR on those 2 caps was 30Ω and 34Ω.
                          • lookimback
                            • Aug 2013
                            • 1489
                            Nope, not fixed. It works fine if I turn it on from the power button, but if I use the remote I get the little sparkles and the buttons become unresponsive. But also, once I unplug it, and plug it back in, then everything will work fine, including by remote. I think I should have recapped the entire board.
                            • ItepK
                              LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
                              by ItepK
                              Hello everyone! I've found this television, and I began troubleshooting it.
                              First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
                              I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
                              After the recapping, all the voltages stableized, however, the issue in the title still remains.
                              I could...
                              01-03-2025, 09:01 AM
                            • Tr0ll
                              by Tr0ll
                              Original T-con:
                              First replacement T-con:
                              10-07-2023, 07:48 PM
                            • burbutsalos
                              55" QLED QE55Q60T Turns on after 1 minute the picture goes bad and get in boot loop
                              by burbutsalos
                              Hello ,
                              The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
                              If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
                              Any ideas what to check?...
                              12-12-2023, 06:06 AM
                            • JJAAMM
                              by JJAAMM
                              Problem
                              07-06-2023, 06:01 AM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
