KDL-46EX621---No Power/No Standby---Bad PS?
  • holmzy
    • Nov 2009
    • 99
    Re: KDL-46EX621---No Power/No Standby---Bad PS?
    90% of sony psu boards are fuse or diode or thermal fuse resistors
    • ALR
      • Nov 2012
      • 111
      I'm guessing that's the only issue but we shall see. Since it was a 4 blink code and that is a mainboard issue as well and now the flow chart is telling me mainboard issue, it probably finally just gave out which is why it won't power on now.
      Seems the last time I thought PS and got the part, it was mainboard. I've only had PS issues when there was a short but I know that's not always the case but lesson learned I guess.
      • ALR
        • Nov 2012
        • 111
        I have a quick question. I have this Vizio where half screen would go black, hit the top corner and it'll fix itself. Took it apart and I replaced the inverter board because a solder pad bridged with a pad on the component next to it and it was obvious this was the issue cause it was the top of the inverter, exactly where you would hit the side to get it to work. But now it's doing it again and slowly getting worse.
        Could it be LCD or inverter(got it used from Ebay) I'll try and get model # later and pix of it but hoping someone may now off hand from experience.
          Ha????
          • holmzy
            • Nov 2009
            • 99
            Originally posted by budm
            Ha????
            sony are very silly with their fuses and there are many on both psu and main boards. if the fuse is fine on the psu was the fuses on the main checked??
            • ALR
              • Nov 2012
              • 111
              So, after getting the replacement board in(found for 98 shipped!) popped it in and got some signs of life. After messing with it for a few and wondering why it wouldn't turn on(standby flashed 5), I took apart the Tcon cover and noticed the flex cables were disconnected from someone tinkering with it before me.
              Got that situated and had the amber/green flashing lights. Downloaded the software update, popped it on the usb and it started right up to the software update screen.
              Mainboard fixed the issue I was having for sure. Thanks for all the help Bud
              • stylishconsultant
                un60j620dafxza - Samsung No Display Problem
                by stylishconsultant
                Hi All,
                Need help.
                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                09-04-2024, 03:26 AM
              • mkdj
                Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                by mkdj
                Dear all,
                I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                Both N-Channel Mosfets: nothing odd
                P-Channel MOSFET number 1:
                source - drain : 117 kOhm
                source - gate: 96 Ohm
                gate - drain: 117 kOhm
                P-Channel MOSFET...
                08-20-2025, 06:08 AM
              • JDC
                (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                by JDC
                ONN 100012588
                Issue: No Power, Then Rebooting After Main Board Change
                Short answer: replace main board and power board
                Technical answer: replace main board and Q306 & Q307 on power board.
                Long answer:
                TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                07-15-2022, 07:39 AM
              • max789
                Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                by max789
                Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                I made the following tests:
                1. Disconnected the main board from Power Board = backlight works.
                2. Connected the main board and disconnected the T-Con = backlights does not work.
                So I ordered a main board from Ebay also BN41-02156A but from...
                01-18-2024, 06:56 AM
