LG 42LG5010 - Bad T-Con ?
  • unit22
    • Jun 2014
    • 29
    • wales
    Hi all, recently acquired this TV, hoping to get it back working again (for my own use).
    Symptom: Bright/White screen, can just about see image but very bright.
    The T-Con board is T420HW02 - 42T04-C04, I have read (on this forum) that the AS15 chip is prone to failure.
    I have done the voltage test as instructed in another thread and these are my results:
    VGMA22 - 7.05v
    VGMA20 - 8.99v
    VGMA18 - 9.49v
    VGMA16 - 12.52v
    VGMA14 - 3.68v
    VGMA12 - 1.43v
    VGMA10 - 1.36v
    VGMA8 - 5.10v
    VGMA6 - 7.63v
    VGMA4 - 14.90v
    VGMA2 - 15.53v
    VGMA21 - 9.17v
    VGMA19 - 11.24v
    VGMA17 - 10.70v
    VGMA15 - 13.38v
    VGMA13 - 1.45v
    VGMA11 - ....... Around +2.0v (increasing and decreasing around 2.0v)
    VGMA9 - .........Around +2.0v (increasing and decreasing around 2.0v)
    VGMA7 - 6.00v
    VGMA5 - 11.63v
    VGMA3 - 15.50v
    VGMA1 - 15.56v
    VCOMF - 6.32v
    VCOM - ........ Around +3.0v (increasing and decreasing around 3.0v)
    V303 - 3.30v
    AVDD - 15.72v
    AVDD_F1 - 15.77v
    VGMA - 15.47v
    VGHC - NIL
    VGL - -6.03V (minus 6.03v)
    VGH - NIL
    YV1C - 2.64v
    INSDA - 3.26
    12VIN - 11.91
    Can someone please decipher these fiquires for me, I have no idea what they should be. Thank you for any help
    Re: LG 42LG5010 - Bad T-Con ?
    The gamma chip is definitely bad. The voltages from VGAMA1 to VGAMA22 should either rise or fall slowly but only one way.
    e.g. 1,3,5,7,9V is OK and 15,10,5,2,1V is OK, but 1,3,2,7,4,10V is not good.
    That's the gist of it - there's a bit more to it but that finds most failures like this one.
    • unit22
      • Jun 2014
      • 29
      • wales
      Thanks for the help tom, much appreciated :-) And thanks for the explanation too, always willing to learn!
      So i need to get a used but working t-con board then! I will report back when it arrives, thanks again
        If you have good soldering technique you can also replace the AS15-F chip.
        • unit22
          • Jun 2014
          • 29
          • wales
          Thought about that tom, but I am not confident in soldering such a small chip lol It is tiny! Soldering parts on the PSU is my limit at the moment
          I do know a guy that can replace the IC chip, but hasn't got back to me on a price. How much do people charge for this repair?
          Cheers
          • unit22
            • Jun 2014
            • 29
            • wales
            Hi
            Thanks again tom, again you were spot on with your advice! The T-con board arrived yesterday and now the TV is working lovely! Really appreciate the help, thanks!!!
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • netgearnetgear
              TCL 43S423 TCON OR PANEL FAULTY???
              by netgearnetgear
              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
              08-20-2025, 06:04 PM
