Re: Vizio XVT3D650SV - Help
I will order a main board then! Thanks for all the help guys!
well, the controller chip (whichever one it might be) is getting 5 volts and turning it to 3.3 and trying to turn on, but isn't
It may be the chip under the one heatsink ? or could be somewhere else and trring to figure it out could be rough.
you would first have to try to figure out where the power button 3.3 volts is coming from to have any clue where to start. even if you find that chip, it could be something else stopping it !Leave a comment:
Hah figures!
Both are the same. I just just tested pins 1-16 on main board and power board. Pushing the button doesnt change anythingLeave a comment:
well. I was hoping for an easy fix like a bad button, BUT, NOT !
do both power supplies give the same results voltage wise?
Did you recheck pin 13 and pin 14 & 16 to see if they show any signs of a voltage rise wile you push the power button (I think you checked 13 but not sure if you check 14 or 16)Leave a comment:
I have 1 pin that has power 3.3v on both sides of ribbon. When power button is pushed it drops off to 0 on both sidesLeave a comment:
OK
I figure it might be multifunction
check for voltage at the 8 pin plug at the main board side (I think it is a J7 plug)
Then recheck the voltages at the power button end to make sure they are the same.
If you find voltage on a pin
Hold the tester in place so that you can see if the voltage drops when you push the power button. If you have several pins with voltage, keep check them to see if one dropsLeave a comment:
The group of picutes "Round 2" IMG_20140703_133842.jpg is the power switch board. The power switch pushing in to turn on/off. If also rotates to interact with the menusLeave a comment:
On post 2 with your first set of pictures: Is that the power button shown on the second to last picture ? is it the bottom one in the picture with the 8 pin connector ?
If it is, does it rotate or push to turn on and off and does it normally do any other functions ?Leave a comment:
I would scrape the tv but I spent a lot on it and barely had the money at the time to buy it and dont have the money now to replace itLeave a comment:
OK, so the main board is not sending the PS_ON signal, so main board is the problem right now.Leave a comment:
OK so no matter which combination (plug in, pushing power button or plug disconnected) it always stays at 0Leave a comment:
so, is pin 13 showing voltage even if the main board is disconnected from the plug ? and is it still showing 5 volts ?
OR
Is it showing no voltages ?Leave a comment:
The TV *normally* goes through a boot up stage when you first plug it in. During that time the vizio logo lights up orange then proceeds to flash orange and white. Once it is complete the logo go back to orange and the power button becomes enabled and you can turn on the TV.
I am guessing the power button will not change the voltage as the tv is not "booted up".
I am not sure I just know that it used to take 1-2 minutes before the power button workedLeave a comment:
No change on pin 13 when pushing the power button with cn202 connected or disconnectedLeave a comment:
ok
That is better
Now you can recheck pin 13 that budm wanted to see the value of when powered on and off and connected to the main board
also check it at the power supply with wires to cn202 disconnectedLeave a comment:
OK the multimeter I had was defiantly NOT matching the new one. Now maybe we can actually get somewhere! Sorry about that guys!!
Here are the readings:
Power board plug
1 5.1-5.3
2 5.1-5.3
3 5.1-5.3
4 5.1-5.3
5 0
6 0
7 0
8 0
9 0
10 0
11 0
12 0
13 0
14 0
15 0
16 0
caps on power board:
C951A 5.22
C951B 5.22
C951C 5.22
C800A 77.7
C800B 77.7
C800C 77.7
Main board
Fuses
F3 5.1
F1 0
Voltage Regulators
U8
in 0
out 0
gnd 0
tab 0
U38
in 0
out 0
gnd 0
tab 0Leave a comment:
I am going to get a new tester this morning. Maybe it is the issue. I will post all new readings one I get it.Leave a comment:
See the picture
ALSO, please check these with the plug from the main board unplugged
USE GREEN marked pins for black probe of the testerLeave a comment:
Assuming...7 Photos -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
