Question?
  • Samsungguy
    • Jun 2014
    • 6
    Question?
    So I bought this samsung 50 inch and open the back off it and new the y-sus board was bad so i look threw the board for busted caps and found none but i did fine a resistor color gold, black, black, brown so replaced with with the same colors, my question is if i buy the kit for this and replace all the mosphets part#RJH3047 and Toshiba K2837 will the resistor work fine or will it blow the board up? samsung model # hp-t5054
  • Hamie
    • Apr 2014
    • 1383
    Re: Question?
    Have you checked the parts in the kit are faulty in your board?
    More importantly have you checked the buffer board ICs for damage/shorts?
    • Samsungguy
      • Jun 2014
      • 6
      Re: Question?
      Yes I checked the buffer boards and there good, I did check the parts and I do have to replace them all. I even check the cap c5709 and its good and the fuses.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        by ohren
        09-08-2023, 05:24 PM
      • ugamazing
        Assistance with identifying resistor value on 820-02918 A2992 board?
        by ugamazing
        Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
        I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
        09-06-2024, 08:33 AM
        09-07-2024, 05:50 AM
