Question?
    Question?
    So I bought this samsung 50 inch and open the back off it and new the y-sus board was bad so i look threw the board for busted caps and found none but i did fine a resistor color gold, black, black, brown so replaced with with the same colors, my question is if i buy the kit for this and replace all the mosphets part#RJH3047 and Toshiba K2837 will the resistor work fine or will it blow the board up? samsung model # hp-t5054
    Re: Question?
    Have you checked the parts in the kit are faulty in your board?
    More importantly have you checked the buffer board ICs for damage/shorts?
      Re: Question?
      Yes I checked the buffer boards and there good, I did check the parts and I do have to replace them all. I even check the cap c5709 and its good and the fuses.
