Panasonic TH-50PX500U
  • PBJ
    • Jun 2014
    • 8
    Hoping you guys can give me some guidance on what my problem is. Thanks
  • PBJ
    • Jun 2014
    • 8
    Re: Panasonic TH-50PX500U
    The power light stays red, no blink. Unless it needs to be interrogated?
    • NickStam
      • Jun 2014
      • 8
      Is it still displaying a picture? Is it frozen?
      • tw2005
        • Oct 2011
        • 6458
        I'll take a punt and say D board. You won't get a SOS blink with that kind of fault. D or DG boards but I have not really worked that kind of fault. It's definitely not Sd/Su/Sc/SS/PSU/ C boards.
        • PBJ
          • Jun 2014
          • 8
          [QUOTE=NickStam;460558]Is it still displaying a picture? Is it frozen?[/QUOTE
          The display isn't frozen. It functions properly just has the bars in front.
            D board is a likely cause. You can check the on board test pattern.
            SM for PX50U, a similar model:
            page 39
            Test patterns somewhere there - can't remember exactly how but think it's a few presses of the buttons to access it. Power off to exit.
            • PBJ
              • Jun 2014
              • 8
              I initiated the self test yesterday and these were the results....
              UV OK
              SND OK
              ADV OK
              MEM OK
              DT1 OK
              DT2
              OK
              AVSWV OK
              AVSWA OK
              QC4P OK
              RTC
              OK
              HDMI OK
              PANEL OK
              SOS: 8
              I initiated the test two additional times and did not have the SOS code. I haven't found in the manual yet what that means but still looking.
                SOS 8 is SS board MID voltage low or electrodes disconnected/loose. Has the TV ever failed to turn on, with a flashing red light 8 times?
                • PBJ
                  • Jun 2014
                  • 8
                  No it turns on every time and the light has always stayed solid.
                  • PBJ
                    • Jun 2014
                    • 8
                    Thinking about ordering a D board and an SS board and give it a try. They aren't that expensive so what the heck.
                      I wouldn't order an SS board if the 8 blinks does not occur. Chances are the SS error could be original from the factory when they did the first test. (It obviously failed so they exchanged the SS board before shipment.)
                      • Andre Gilbert
                        by Andre Gilbert
                        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                        11-20-2024, 08:52 PM
                      • AquaMan Ua
                        by AquaMan Ua
                        05-17-2025, 09:40 AM
                      • CDNBrewer
                        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                        by CDNBrewer
                        Hello Everyone,
                        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                        Symptoms:
                        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                        • I swapped the Left and Right surround
                        08-05-2025, 09:29 PM
                      • stecos
                        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                        by stecos
                        Hi everyone!
                        For my passion for technology I'm now collecting several...
                        11-28-2022, 11:39 AM
                      • aa10aa10
                        Panasonic Toughbook CF-33 mk1 BIOS repair
                        by aa10aa10
                        Good day,
                        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                        01-21-2025, 06:13 AM
