Hoping you guys can give me some guidance on what my problem is. Thanks
Panasonic TH-50PX500U
Re: Panasonic TH-50PX500U
D board is a likely cause. You can check the on board test pattern.
SM for PX50U, a similar model:
page 39
Test patterns somewhere there - can't remember exactly how but think it's a few presses of the buttons to access it. Power off to exit.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I initiated the self test yesterday and these were the results....
UV OK
SND OK
ADV OK
MEM OK
DT1 OK
DT2
OK
AVSWV OK
AVSWA OK
QC4P OK
RTC
OK
HDMI OK
PANEL OK
SOS: 8
I initiated the test two additional times and did not have the SOS code. I haven't found in the manual yet what that means but still looking.Comment
SOS 8 is SS board MID voltage low or electrodes disconnected/loose. Has the TV ever failed to turn on, with a flashing red light 8 times?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I wouldn't order an SS board if the 8 blinks does not occur. Chances are the SS error could be original from the factory when they did the first test. (It obviously failed so they exchanged the SS board before shipment.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
...1 Photo11-20-2024, 08:52 PM -
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
Channel: BIOS Requests ONLY!
by CDNBrewerHello Everyone,
I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
Symptoms:- Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
- Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
- I swapped the Left and Right surround
by stecosHi everyone!
For my passion for technology I'm now collecting several... - Loading...
