tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
  • PNI E.
    • Nov 2024
    • 101
    • Italy
    Originally posted by Diah
    if the right side was Blank clear White then T-CON issue. blank black also could be T-CON ..
    this test was for just to check if there are distributed at image.. then Panel fault
    diah…I’m really sorry but I can’t remember. What I can say you it s before all your help, the tv was no image but no black black because there were lights from the back light, in some point more than other. When I put the jumper with the right side off and the left side on, there were no big changes always dark but with light on and in some point more light. When I unplug the left side and plug the right side, I saw a perfect image on the right side, and I remember very clearly that the other part now were more uniform, I don’t remember if white or black, but I remember it was all the same not with spots with more lights
    • lotas
      • Jan 2016
      • 4813
      • Russia
      The problem may be in these protective diode assemblies, disconnect this yellow cable and check the image, but I'm afraid this test will not work without a jumper on the t-con.
      • PNI E.
        • Nov 2024
        • 101
        • Italy
        So I have to disconnect the dark flat and with the jumper on I check the image….guys I wrong….i didn’t think the pad could take off, tomorrow I ll try before to mask again the flat and see if I have changes maybe I change the size of the tape, if I don’t have changes I try to solder again a jumper on the sock of the ribbon flat…Broke for broke I try..and after we ll see at least I can buy a new tcon board…
        • PNI E.
          • Nov 2024
          • 101
          • Italy
          Hi guys I tried to mask the right ribbon, also with different size of tape but nothing it s no picture. So I make some measure on the tcon and buffer board I give u the pictures with the valor. I did with the ribbon plugged in and with the ribbon of the right side unplugged. Do u suggest to try to make again the jumper and this time I have to make on the socket of the ribbon because I broke the pad….what you suggest? I tracked the fbbew that is still ok and it s the first pin the nearest on the socket. Do you think I have to connect this with the first pin the nearest near the brocken pad on the other side? Because that I can’t track because I break but I think it s the first pin near the Brocken pad. Thanks for your help
          • Diah
            • Feb 2013
            • 6502
            remove all mask .. use very thin wire and do the jumpers with pin 1. post photos of the whole screen when you disconnect left and right.
            • PNI E.
              • Nov 2024
              • 101
              • Italy
              #26
              diah sorry i broke everything haha some tin went on the socket and put all in short i tried to clean the mess but...im sorry i make all of your lose your time. but i dont give up, i buy a new tcon and when it comes we start again hope i learn the lesson. can i buy atcon with the same code or must be from the same tv?
              • PNI E.
                • Nov 2024
                • 101
                • Italy
                #27
                hi guys I’m back, I know like a nightmare. I bought from china the tcon, because it were cheap like 25 dollars, so I didn’t give up…so if u still let me you an help I ll be really really thankful.
                now I made the jumper again, this time I used a nice really small wire, so I didn’t make a disaster. After make the jumper, with the right ribbon plug off and the left plug in I don’t have nothing in the screen. If I unplug the left sid and plug in the right side, for the first 20 30 seconds I don’t have pictures, but the screen changes. Now it’s black on the right side and white with grey orizontal lineon the left side. After 20 30 seconds I have audio and picture on the right side and in the left I have white with grey orizontal line. The orizontal line goes also on the right side where we have the picture, but it s not so bad.
                so I put the photo so you can see all, and if u have any idea how to go forward I will listen you. So please help me thanks to all
                • lotas
                  • Jan 2016
                  • 4813
                  • Russia
                  #28
                  Disconnect only this cable.
                  • PNI E.
                    • Nov 2024
                    • 101
                    • Italy
                    #29
                    Thanks for your answer. If I disconnect the buffer flat I have image on almost all the panel, only 20 30 cm are white with grey strips. If take a photo of the buffer board so if u need I check somenthing or I do somenting…
                    • PNI E.
                      • Nov 2024
                      • 101
                      • Italy
                      #30
                      we can’t do nothing about this tv?
                      • PNI E.
                        • Nov 2024
                        • 101
                        • Italy
                        #31
                        Hi guys, so I put the tape on the buffer flat, and I have picture, it s not so nice picture because I have all light on the bottom of the display but I think I can't make better, or do u think I can do something for make it better? Thanks for all the support you are all great. If someone have some idea how to have a better image I'm here
                        • lotas
                          • Jan 2016
                          • 4813
                          • Russia
                          #32
                          All that remains is to replace the backlight and get rid of the dark spots below...
                          • PNI E.
                            • Nov 2024
                            • 101
                            • Italy
                            #33
                            so you mean it s a back light problem too….it s really trash hahaha…thanks iotas for your help, u and diah helps me a lot. I think I don’t try to change the back light because the panel it s no frame…so I think the panel is on with tape? I never take of a panel without frame I think it s a little too much for my ability haha
                            • EazyBone
                              • Jun 2023
                              • 1362
                              • United states
                              #34
                              Also you need a new diffuser too because I can see it's already cracked. So backlights and diffuser also. Agree toss it.
                                • 12314
                                • U.S.
                                #35
                                • PNI E.
                                  • Nov 2024
                                  • 101
                                  • Italy
                                  #36
                                  i think it will be in the trash...a little sad because the tv was 900 euro of tv....but change backlight in that type of dispaly without frame, it s a really harrd job and then maybe also the diffuser is gone...it stay in this way still a little until i buy a new tv thanks for all
                                  • stylishconsultant
                                    un60j620dafxza - Samsung No Display Problem
                                    by stylishconsultant
                                    Hi All,
                                    Need help.
                                    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                    09-04-2024, 03:26 AM
                                  • Fly_Among_Stars
                                    VIZIO E70-E3 Half picture with half TCON
                                    by Fly_Among_Stars
                                    I have a VIZIO E70-E3.
                                    Symptoms: Black screen, no picture, but LED backlights are working.
                                    I probed the power board and voltages are as listed on the board.
                                    Main board appears fine, too.
                                    I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                    There are two separate ribbon cables feeding the LCD.
                                    If both are connected, the screen is black.
                                    If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                    04-24-2023, 08:20 PM
                                  • iglitare
                                    by iglitare
                                    09-04-2025, 07:13 AM
                                  • koby058
                                    vostro comes up with back light but no picture
                                    by koby058
                                    Hi people!!
                                    The owner said it showed bad picture once in a while (attached)
                                    I see that there is back light but no picture.
                                    I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                    Also attached schematic and BDV
                                    LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                    07-13-2025, 01:03 PM
                                  • slimsoul
                                    Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                                    by slimsoul
                                    Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                                    I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                                    I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                                    The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                                    03-12-2024, 03:55 AM
