Circuit identification for LG42PC55
  • terabit
    • Jan 2014
    • Slovakia
    Can someone help me idetify IC3 35H 730
    Or have someone schematic for this TV LG42PC55 ?
    Miroslav
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Circuit identification for LG42PC55
    Tom66 has the service manual see in his signature for link.
    It doesnt seem to mention any fo the parts shown in your picture - what board is it on
    Board make & number may help but it may be a proprietary part. I see there is another on the board the same
      Can't tell you exact part but it is an isolator for translating ground referenced logic down to the FGND voltage. for the buffer boards.
      • Techie_hobby1
        Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
        by Techie_hobby1
        Need some help please with a few components on this small board so that I can troubleshoot the circuit.
        The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
        J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
        J2 - to DC Output
        J3 is Battery cell connector
        however I am struggling to identify if:
        Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
        07-24-2025, 12:43 PM
      • Alimash
        op amp circuit function?
        by Alimash
        I am repairing a ups which doesn't turn on ,it has the following ICs:
        SG3525 used to drive inverter mosfets.
        couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
        A LM358 and TL074 for control mechanism and of course the uController.
        The SG3525 is shutting down every time the ups is turned on.
        I want your help to know the function of LM358 and TL074 in the system.
        I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
        07-31-2025, 07:45 AM
      • Astonished
        Fixing the Charge Circuit of the Batteries of the DC Motor
        by Astonished
        Hi friends of electronics
        What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
        The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
        Please help me fix this circuit.
        (the datasheet of the IC: https://pdf.datasheet.live/28...
        01-28-2025, 06:24 AM
      • rddube
        Lenovo L490 Ram voltage circuit malfunction
        by rddube
        Hello friends,
        Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
        I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
        07-15-2025, 04:41 PM
      • Tarot Superstars
        Short Circuit tester
        by Tarot Superstars
        Hello.
        I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
        The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
        Link
        The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
        https://www.youtube.com/watch?v=0eixDdCpiO4
        My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
        09-25-2023, 09:11 AM
