Hi guys, have this sony with no picture. It powers on, after about 15 seconds, backlight comes on but no picture (i was told it had sound but i have not heard it for myself). I checked psu voltages and all were in spec, 12v was a little low at 11.56, but it did not drop further than that. I checked the power regulation IC (ISL976) on the TCON which was supposed to supply the voltages needed for the TVCON board and found it only put out 3.3v, Avdd was at only 11.56, and Von and Voff were both at 0v. I ordered a new TCON and nothing changed, same voltages. I uplugged the connectors going from the panel to the tcon and the voltages come up. looks like the ribion cables from the TCON are a little melted. Faulty cables or bad panel?Thanks!
sony KDL-46s4100 no picture
by iglitareHi,
i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
Backlight seems to work, Sound (Setup menu after reset) works.
If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
With my small knowledge i would think at least the cables are good.
Can this happen because of a bad tcon board?
Or is it always a bad/shorted... -
by Daren87Hello everyone,
I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the... -
by CyberPhoenixHello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... -
by noisykid5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
- Loading...
