Someone can Check my UE55MU8000 Bios, Backlight no screen no standy
  • Asraf Atb
    • Jan 2025
    • 9
    • Italy
    hi following my post of yesterday i manage to extract the Bios from the chip of my UE55MU8000, can some have a look and see if is corrupted like other MU series that happen often, appreciate in advance
  • lotas
    • Jan 2016
    • 4752
    • Russia
    Yes, I can, the dump has been checked and fixed, try it, don’t forget to set and write the status register (0x88, 0x42) after writing the corrected dump.
    • Asraf Atb
      • Jan 2025
      • 9
      • Italy
      thank for reply I need to put here ?
      • lotas
        • Jan 2016
        • 4752
        • Russia
        What programming software do you use? You need the program "NeoProgrammer V2.2.0.10".
        • Asraf Atb
          • Jan 2025
          • 9
          • Italy
          my friend I’m using ASprogrammer and I find this menu to edit reg can you check
          • lotas
            • Jan 2016
            • 4752
            • Russia
            ASprogrammer does not work correctly with the status register, install "NeoProgrammer V2.2.0.10".
            • Asraf Atb
              • Jan 2025
              • 9
              • Italy
              fixed my friend thanks you
              • Asraf Atb
                • Jan 2025
                • 9
                • Italy
                Hi my friend everything is working, only wifi look not working like there is not Mac adress in about tv, could be something related to the firmware or I could damaged wifi of the TV, let me know
                • lotas
                  • Jan 2016
                  • 4752
                  • Russia
                  This firmware has no effect on Wi-Fi.
                  • mitchw
                    HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                    by mitchw
                    Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                    After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                    After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                    I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                    04-29-2025, 03:45 PM
                  • BlueNitesFire
                    I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                    by BlueNitesFire
                    So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                    03-08-2025, 03:49 PM
                  • Technodoc
                    ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
                    by Technodoc
                    Asus laptop G614JZ-N3012W Rog Strix with i7
                    Mainboard G634J-PMV-VGT
                    6050A3441302-MB-A01
                    2023-02-10
                    Power button works okay....power light goes on
                    Red "bottom" leds go on
                    Charging led works
                    Fans do not spin, capslock key does nothing, screen stays black
                    I would like to program the bios again, to rule out a corrupted bios.
                    However I run into a size error
                    The bios chip is a Winbond 25R256JVEN
                    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                    02-24-2025, 04:46 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
