Someone can Check my UE55MU8000 Bios, Backlight no screen no standy
  • Asraf Atb
    • Jan 2025
    • 9
    • Italy
    hi following my post of yesterday i manage to extract the Bios from the chip of my UE55MU8000, can some have a look and see if is corrupted like other MU series that happen often, appreciate in advance
  • lotas
    • Jan 2016
    • 4966
    • Russia
    Yes, I can, the dump has been checked and fixed, try it, don’t forget to set and write the status register (0x88, 0x42) after writing the corrected dump.
    • Asraf Atb
      • Jan 2025
      • 9
      • Italy
      thank for reply I need to put here ?
      • lotas
        • Jan 2016
        • 4966
        • Russia
        What programming software do you use? You need the program "NeoProgrammer V2.2.0.10".
        • Asraf Atb
          • Jan 2025
          • 9
          • Italy
          my friend I’m using ASprogrammer and I find this menu to edit reg can you check
          • lotas
            • Jan 2016
            • 4966
            • Russia
            ASprogrammer does not work correctly with the status register, install "NeoProgrammer V2.2.0.10".
            • Asraf Atb
              • Jan 2025
              • 9
              • Italy
              fixed my friend thanks you
              • Asraf Atb
                • Jan 2025
                • 9
                • Italy
                Hi my friend everything is working, only wifi look not working like there is not Mac adress in about tv, could be something related to the firmware or I could damaged wifi of the TV, let me know
                • lotas
                  • Jan 2016
                  • 4966
                  • Russia
                  This firmware has no effect on Wi-Fi.
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    11-14-2025, 04:04 PM
                  • mitchw
                    HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                    by mitchw
                    Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                    After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                    After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                    I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                    04-29-2025, 03:45 PM
                  • BlueNitesFire
                    I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                    by BlueNitesFire
                    So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                    03-08-2025, 03:49 PM
                  • Technodoc
                    ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                    by Technodoc
                    Asus laptop G614JZ-N3012W Rog Strix with i7
                    Mainboard G634J-PMV-VGT
                    6050A3441302-MB-A01
                    2023-02-10
                    Power button works okay....power light goes on
                    Red "bottom" leds go on
                    Charging led works
                    Fans do not spin, capslock key does nothing, screen stays black
                    I would like to program the bios again, to rule out a corrupted bios.
                    However I run into a size error
                    The bios chip is a Winbond 25R256JVEN
                    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                    02-24-2025, 04:46 AM
                  • istvanszasz99
                    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                    by istvanszasz99
                    Product Name: Razer Blade 15 (2022)
                    Product ID: RZ09-0421
                    Motherboard: CH580
                    BIOS Versions I work with: 2.02 & 2.06
                    Bios File Size: 32,768 KB
                    Dear Forum Readers!
                    I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                    I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                    The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                    !!! MY RAZER BLADE...
                    11-24-2025, 05:52 PM
