Panasonic TX-L37V10B possible mura or shadow or dark areas
  • statalite
    • Jun 2014
    • 18
    • England
    Re: Panasonic TX-L37V10B possible mura or shadow or dark areas
    Originally posted by tom66
    It's a LOT of work to take apart a large LCD like this (anything around 40" or bigger is "large" in my mind.)
    You're dealing with a piece of LCD glass about 1.5mm thick and 37" diagonal. It is attached to the electronics via delicate bonded tab drivers. If you crack the panel or break a bond, game over. You need a couple hours free ideally, because you want to work nice and slow. No awards given for doing it fast and screwing it up.
    I wouldn't recommend it unless you've done it before or can afford to break a panel accidentally. I still hate doing them even after doing it about 5 times. On my third panel I was assembling I was 1mm off on the glass alignment and plastic. I pushed down on the metal frame and cracked the panel. Ruined a nice 40" Sony panel right there. It's something I would NOT recommend a newbie try.
    Following this advice, I have been put right off. bammbammfran made it look easy to do on his smaller monitor, but I am a newbie at this.
    For bammbammfran here is a photo of the back, I had to take the cover off again which took an hour to take on and off.
    I wonder if a panasonic service centre will touch it, possibly at significant cost I would imagine?
    • bammbammfran
      • Apr 2014
      • 476
      HI
      Panasonic won't touch these or they will tell you what apple does " these can not be fixed "
      But I did 3 27" apples last week alone, so they are full of shit !!!
      I open 30 inchers all the time, so 7 " more diagonally is not that much larger
      and can be handled with one set of hands
      It looks like yours as an upper tcon board like the 24" in my video does, so the top ribbons are about the same setup.
      Instead of you bulb plugs being on just one side like on my 24
      yours looks like it has one on the left bottom and right bottom
      otherwise it should be basically the same setup.
      leds are basically the same as these ccfl ones, but their bulbs are at the very bottom and on bigger screens, at the top too. but the large plastic piece in the middle bottom layer of those is thicker.
      video of an apple led is here
      http://youtu.be/orJ-zEdSAAQ
      I have a 40" here that I may open and do a video of tomorrow if I can find the time.
      • statalite
        • Jun 2014
        • 18
        • England
        Still dubious, but always curious. Looking forward to your video of the 40" bammbammfran.
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Off topic but I just broke my 1st on Friday evening. 46" Toshiba with Samsung panel. Tab bond issue that was easily fixed but cracked the panel when tightening the first screw. Screen misalignment. Was pretty heartbreaking when I heard the pop.
          • bammbammfran
            • Apr 2014
            • 476
            Ok
            Actually the one I just did ended up being a 46" with an already broken screen from falling off of a wall, so it was getting recycled.
            it was actually easier to disassemble than the 27 apple
            Will upload that video later tonight
            • bammbammfran
              • Apr 2014
              • 476
              This is why you need to take your time and make sure everything is sitting freely and where it belongs first
              next time you do one for tab bonds which does not require the glass to be lifted, tape the glass to the plastic sides in a few places away from the tabs so that it doesn't lift accidentally out of the channel
              Sorry about your mishap.
              • bammbammfran
                • Apr 2014
                • 476
                Cinematography is not great since I forgot how big this was and I was out of camera frame in a few places but this should give you an idea
                http://youtu.be/dF_KVGMOwNo
                • statalite
                  • Jun 2014
                  • 18
                  • England
                  #28
                  should the air temprature of a room or direct sunlight be a consideration when taking a tv apart?
                  when removing bits of "tape" do these all have to be replaced when putting back together?
                  • bammbammfran
                    • Apr 2014
                    • 476
                    Most of the tape is not necessary (especially like when apple went overboard on theirs)
                    Tape tends to stop airflow and trap heat which isn't usually a good thing.
                    I actually think that the lcd panels should have venting to let heat escape the panel.
                    If you feel like replacing it, look for some HVAC foil tape
                    Duck brand has one that is inexpensive, 3m also makes some but that is probably more costly, I use one made by venture tape.
                    temperature and or lighting is not a factor.
                    Dust is the biggest issue. it won't hurt anything but it can cause cosmetic spots in the panel
                    either will be white if below the films or dark if near the top.
                    So pick a clean area with enough space to lay out at least two panel sizes
                    IF you space is not really clean, you can get some cheap painters plastic dropcloths and fence off an area.
                    these are usually really thin plastic and when unrolled or unfold, they get some static properties, so they can help to grab floating dust.
                    A good thing to lay the screen and films on is paper. (Xmas wrapping paper should work well)
                    • statalite
                      • Jun 2014
                      • 18
                      • England
                      #30
                      Just looking at the image I uploaded with the back off.
                      I'm thinking I would not know where to start with the next part to take apart or unscrew, any ideas guys?
                      Is there a method/ logical way to disassemble?
                      I prob wont start for at least a week as I need to get the equipment.
                        • 31301
                        most panels are held in the steel pcb frame with screws from the sides.
                        • bammbammfran
                          • Apr 2014
                          • 476
                          Before you do anything, take a few more pictures and get some tape for marking parts and making botes and some different color markers to make different size screws.
                          Pictures as you do a step or two will also help you retrace your way back together
                          It looks like the first thing you will need to do is remove the front plastic trim
                          this is probably held with screws at the perimeter. the speaker and power button and remote sensor may go along with it, so you'll have to unplug those wires.
                          Then is looks like you will have to remove the covers in the two large red circles to access two boards connections that lead to the panel itself- Be gentle on the flat ribbons under the cover at the red arrow !!
                          After those are unplugged from the lcd panel, then start taking out any screw that looks like it is holding the large rear tin piece. I think your other boards will come along with this large piece.
                          • BigPete
                            Panasonic Heatpump Dryer Repair
                            by BigPete
                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                            Unfortunately the whole machine has to come apart to fix it.
                            I have...
                            11-01-2025, 06:40 PM
                          • Andre Gilbert
                            by Andre Gilbert
                            11-20-2024, 08:52 PM
                          • AquaMan Ua
                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                            by AquaMan Ua
                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                            05-17-2025, 09:40 AM
                          • stecos
                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                            by stecos
                            Hi everyone!
                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                            Having said that I come to the gist of my post on the forum as the title suggests.
                            For my passion for technology I'm now collecting several...
                            11-28-2022, 11:39 AM
                          • Mnawar27
                            Panasonic CF-H2AU24EF3 bios locked
                            by Mnawar27
                            Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                            I need help to remove it,
                            thankyou all.
                            SN; 2FKCA26876...
                            11-16-2024, 08:00 AM
