Sony KDL-37EX402 the TV in dead, no LED, motherboard problem.
This topic has been answered.
  • yoritomo
    • Sep 2012
    • 155
    • Belgium
    Hello
    The TV does not show any sign of life , I started the troubleshoot as this , no power Led, no reaction when pressing the power button.
    I checked the Power coming out from the power supply, the 3.3V_standby is correct and steady, then I checked the 1.2V_standby produced by IC6001 which Is good as well.
    So I decided to control the main IC , IC4000 , he does not output any oscillation on the Xtal, Then I am now bloacked there.
    The schematic is downloadable at Eletrotanya website , the schema is weird because the processor is not represented with any Xtal output, but obviously it has one.
    Thanks you for your hint and help.
  • Answer selected by yoritomo at 02-25-2025, 06:59 AM.
    lotas
    • Jan 2016
    • 4966
    • Russia
    Originally posted by yoritomo
    Yes but I don't have any more good sources for dumps, before I had a pro subscription to Euras services, but it is finish now. I could not find it in download,
    Try... (Nand +Spi)
    • nomoresonys
      • 12334
      • U.S.
      Maybe start with powerboard, simple first, check over and reflow any solders on bottom of board that looks suspect, sometimes they look fine but are not. Also check all diodes and resistors on top of board.
      • nomoresonys
        • 12334
        • U.S.
        You can put links to schemo's here, not many have time to chase them down, help others help you.
        • yoritomo
          • Sep 2012
          • 155
          • Belgium
          Hello
          Thank you for the replies, yes sorry, there is the link to the schema below. The power supply works fine, but the processor never orders the main power to start by the POWER_ON pin.
          https://elektrotanya.com/showresult?...=&kat2=all
          Be careful in this schematic, it is a bit weird the main chip is diplayed in many pages in it's different sections.
          I have some new informations, I have been in the wrong way due to the malfunction of the test lead of the oscilloscope, actually the processor is running, I could see the oscillation in proper frequency. The reset circuit is working.
          I then decided to check the keyboard , but the power button is powered and works fine also. No power is going to control any of the 4 front LEDs.
          I start to have some doubts about the NAND chip firmware. Perhaps a good bet to try flashing it.
          Have a better day than here, it is a storm with heavy rain ...
          • lotas
            • Jan 2016
            • 4966
            • Russia
            In addition to nand, there is also a spi flash IC4104_M25P10A.​
            • yoritomo
              • Sep 2012
              • 155
              • Belgium
              • lotas
                • Jan 2016
                • 4966
                • Russia
                Try... (Nand +Spi)
                • yoritomo
                  • Sep 2012
                  • 155
                  • Belgium
                  Thank you so much for these dumps, may I ask where did you find it ?
                  I wanted to flash IC1404, but it is not even readable or detectable by the programmer, the chip is dead I will order a new one, I don't have it in stock or salvage unluckily.
                  The number of the NAND chip number does not match with the number of the file you sent.
                  • lotas
                    • Jan 2016
                    • 4966
                    • Russia
                    Everything should match, what doesn't match with you, where, post a photo, programmer log....
                    Nand:IC4704=H27U1G8F2BTR
                    SPI Flash:IC4104=M25P10​
                    • yoritomo
                      • Sep 2012
                      • 155
                      • Belgium
                      Yes sorry, you are right, I was watching in the schematic, there the number is not the same, but on the PCB the IC number is matching.
                      I will come back with some news when I will receive the small chip.
                      Have a nice day .
                      • yoritomo
                        • Sep 2012
                        • 155
                        • Belgium
                        Hello, I have some news, due to the continuous strikes of the post services here in Belgium, I just received the chips yesterday from Amazon. Cheap and I ordered 5 and I got 8 .... by the way I doubt all of them are really working , you know what I mean.
                        Anyway, the first one I tried, was flashed with success and the TV set is now working fine just replacing IC4104.
                        Thank you again for your help.
                        • lotas
                          • Jan 2016
                          • 4966
                          • Russia
                          OK!
                          • Yanleb
                            Sony XBR-55X810C GN1T Chassis dead in the water, no white or flashing LED
                            by Yanleb
                            Hi, I have this Sony XBR-55X810C that was working when it was last used. It has been stored with the power cord disconnected for two years. Now, reconnecting the power cord it shows nothing. No white power LED, no flashing LED. It is dead in the water.
                            On the power supply, the STBY3.3V standby voltage is OK. The POWER_ON has 3.4V and the power supply turns on, supplying 12V to the main board. This is pretty strange.
                            On the 1-894-595-12 (A2072598B) main board, I did follow the troubleshooting section 3-2-2. NO POWER-U-Com Failure for no power, and the only abnormality...
                            11-30-2025, 11:34 PM
                          • thstuff
                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                            by thstuff
                            A) TV initially dead
                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                            12-26-2024, 09:10 PM
                          • tk3000
                            Dead Laptop Motherboard, then refurbished one installed...
                            by tk3000
                            My venerable and old laptop (Toshiba Satellite P75-A7200 equipped with an i7-4700MQ, circa 2014) and previously a powerful machine during its heyday is no more. Have been using it for many years, but about 3 months ago it went kaputt for no apparent reason (left it on overnight [normally it goes to standby mode after some idle time], and in the morning it was cold dead with no boot, no post, no leds; nothing at all).
                            Since the 1990s I have been building custom desktop computers, etc; but it has been few years since my last built one and for the last 15 years I have built very few...
                            08-20-2022, 08:45 AM
                          • bohaboha
                            SONY KDL-46R473A ALMOST DEAD NO STB
                            by bohaboha
                            Hello to everyone in this wonderful forum.
                            I have this SONY LCD TV KDL_46R473a
                            PSU GL5 APS350 :1-888-122- 12
                            MAINBOARD FY13_EU IP-012C101-4010
                            black screen ,no STB no life almost death.
                            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                            Also 3,5,and 12v are on.
                            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                            don't know what to do next all suggestions and advice are very welcome​...
                            04-24-2025, 04:40 PM
                          • Talyn
                            Sony 55W905 dead
                            by Talyn
                            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                            Any advice? Thanks!
                            04-15-2024, 08:14 AM
