Panasonic NV-V8000 cable
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 337
    • D12
    Hi to all. I was wondering if anyone here got some parts for NV-V8000 vcr maybe. I am searching the whole internet and just can't find any parts for the old tank
    I got two cables broken on the connector side, one has broken small plastic part that I assume from factory because I was the first one to open it, and it look like that, don't make some difference in work except aesthetic. But other connector on wire got broken wire off the connector.Connector was in very bad condition just like the whole vcr I restore all other parts only that connector got weak plastic duo to nicotine smoke and heat. I would like to replace the whole cable not just connector, but if someone have connector that would be also great.
    here is those two cables
ID:	3551869 Click image for larger version
ID:	3551870 Click image for larger version
ID:	3551871 Click image for larger version
    • 31314
    it *may* be a JST connector.
    what is the pin spacing in mm?
    and show the socket.
    • Thermaltake
      Brain badcap
      • Aug 2015
      • 337
      • D12
      Didn't see that on one connector it's sayin JAE (Japanese Aviation Tehnology), probably manufacturer from connector. Going to contact them if they maybe know where to buy one here in Europe or something.
      I google JST connectors they are all closed, this one is open on one side and have how to call it combs that you insert wires inside and they make connection inside like that. Similar to RJ45 when you press it.
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 337
        • D12
        I'll measure it tomorrow, didn't have time today.
        Here is picture of socket
        Click image for larger version  Name:	1.jpg Views:	0 Size:	2.55 MB ID:	3552259
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 337
          • D12
          Mr beta byte is sending me the cables, guy who fix VCRs on yt. Special thanks to him. Hope I will sort it out when they arrive.
          • e-repair
            Broken connector on an electric boat power steering
            by e-repair
            Hey, i have to repair an electronic board on an electric power stearing. the package was damaged during delivery and the connector was broken. but i can't find a part. the connector is the same BUT reversed as fiat power steering. I searched on digikey, mouser and aliexpress and i can't find any part similar. it's an uflex electric power steering, but i don't have more reference on the power steering block. if needed, i can buy any complete part just to recover the conector on the board and put it on this board...
            09-24-2025, 07:30 AM
          • Tomylee
            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
            by Tomylee
            Sorry for the person who’s going to read all this !
            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
            07-11-2025, 11:52 AM
          • gabri2211
            Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
            by gabri2211
            Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
            This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
            This NEXUS connector broke.
            Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
            The Xbox has a power supply that provides 12 volts on all outputs, so the power...
            07-28-2025, 07:13 PM
          • 5mall5nail5
            Help identifying connector for ASUS 4090 Strix RGB LED connector
            by 5mall5nail5
            Hi All -
            I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
            Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
            05-04-2025, 07:47 AM
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
