Tv Smarttech 43 smd components broken identification
  • labello
    • Mar 2018
    • 252
    • italia
    Originally posted by Diah
    this has nothings to do with T-CON.. T-con had its own Fuse... the problem still at MB... DC to DC of 12 VCC not only one Mosfet SI3407-TP. the other one too... its like PNP / NPN circuit
    Hi if you talk about those around here i already test it there are good . Thanks
    • lotas
      • Jan 2016
      • 4803
      • Russia
      Yes, what are you listening to, without the T-CON connected, the mosfet also heats up and burns out?, look for a problem on the T-CON, what could be shorting it out.
      • labello
        • Mar 2018
        • 252
        • italia
        Hi i just finished to look at t-con board it seems that most capacitor are shorted. I put one leg on the ground and meter gives me sound on bot side.. Maybe is better to find another one ..
        • lotas
          • Jan 2016
          • 4803
          • Russia
          Which ones are these?​
          • Diah
            • Feb 2013
            • 6497
            for which reason the T-CON had one Fuse for 12VCC ,, are this Fuse dummy !!!. if you are talking on short you have on T-CON... use 2 batteries 1.5V so u have 3 V will low current and fed the Fuse with + and the - to t-CON chassis let see if this 3V will die ..
            • labello
              • Mar 2018
              • 252
              • italia
              #26
              Hi do you mean right here injection 3v right here, and measured on the t-con 3v test point ? Thanks
              • lotas
                • Jan 2016
                • 4803
                • Russia
                #27
                Do you have a laboratory power supply?
                • Diah
                  • Feb 2013
                  • 6497
                  yes you have point on this rail u can use it. and see the F on both side if there 3V
                  about laboratory power supply, can be used after the 3V test ok... then you can increase
                  • labello
                    • Mar 2018
                    • 252
                    • italia
                    #29
                    Yes i have this one maximum 30v
                    • labello
                      • Mar 2018
                      • 252
                      • italia
                      #30
                      Ok so for start 3v and with amp? I have thermal camera also, to see if any component getting hot(it could be a short right)
                      • lotas
                        • Jan 2016
                        • 4803
                        • Russia
                        #31
                        Apply 8 - 10 volts to these points and increasing the amperes, see what starts to heat up...​
                        • labello
                          • Mar 2018
                          • 252
                          • italia
                          #32
                          Hi I'm already doing what you say , first when I plugged in the camble, it going a little spark then the power supply going on protection (suppose short) then it seems that chip and a diode . Thank you
                          • labello
                            • Mar 2018
                            • 252
                            • italia
                            #33
                            Guys I replace the new t-con and notting happened, no image only led on. So I'm guessing those components are similar or not? Thanks a lot
                            • labello
                              • Mar 2018
                              • 252
                              • italia
                              #34
                              Doesn't matter guys. I will buy another main board and solve this night mare. Thanks for your time
