Tv Smarttech 43 smd components broken identification
  • labello
    • Mar 2018
    • 252
    • italia
    Hello everyone i can't find anything about this smd because it's completely destroyed, no mark on it, the tv turn on backlight is on
    but no picture, I check voltage on t-con board any voltage, the fuse is good. I don't know if i can replace something similar but I don't know what. Thank you so much for the reply
  • lotas
    • Jan 2016
    • 4708
    • Russia
    It is necessary to indicate not the TV model, but the motherboard number (model, chassis...).
    • labello
      • Mar 2018
      • 252
      • italia
      Thanks man ..
      Here those pictures about chassis and marks on the board, i just taken
      • lotas
        • Jan 2016
        • 4708
        • Russia
        3407 - Mosfet SI3407-TP
        • labello
          • Mar 2018
          • 252
          • italia
          Thanks man, do you think can i find this mosfet in other mainboard? Or should I order by new one..? Thanks again
          • lotas
            • Jan 2016
            • 4708
            • Russia
            https://alltransistors.com/mosfet/tr...ansistor=53760
            • labello
              • Mar 2018
              • 252
              • italia
              Thanks man I'll let you know soon
              • bohaboha
                • Nov 2012
                • 1017
                • sweden
                You are unbeatable and just fantastic thank you
                • CuriousJohn
                  Ordained
                  • Dec 2018
                  • 134
                  • Great Britain
                  ooow that cooked, Gods house is below it the "I AM" 🤣, once repaired do not watch porn on it again or God will nuke it a second time from his house.
                  As you where fixing stuff and been all productive...
                    SMDFlea commented
                    Editing a comment
                    What is this gibberish
                • labello
                  • Mar 2018
                  • 252
                  • italia
                  Nono my friend use it very less, and some how it blwn then i don't know if he watch porn Hahaaaaa
                  • labello
                    • Mar 2018
                    • 252
                    • italia
                    Guys I replaced the new one and again he blown up. Dammed something couse this problem 😡
                    • labello
                      • Mar 2018
                      • 252
                      • italia
                      Guys i replace a second one and turn it on without t-con connector and it doesn't blown up. Then i measure bolt pin on board where two cable red comes and i have 12.30 both pin. So it's seems the problem is t-con itself...🤔 i also checked the fuse on t-con board and it's fine. It's very strange isn't... thanks again
                      • lotas
                        • Jan 2016
                        • 4708
                        • Russia
                        This mosfet is a 12v switch to power T-CON, panel, look for T-CON, what could be shorting...
                        Also check the LVDS cable itself to see if it is shorting.
                        • labello
                          • Mar 2018
                          • 252
                          • italia
                          Hi the cable is okay.. the problem is i can't check those voltages when the tv is on because the mosfet blows up again.. Thanks
                          • lotas
                            • Jan 2016
                            • 4708
                            • Russia
                            Why supply power, you need to use a multimeter to check what is shorting on the t-con on this 12v bus.
                            • Diah
                              • Feb 2013
                              • 6416
                              this has nothings to do with T-CON.. T-con had its own Fuse... the problem still at MB... DC to DC of 12 VCC not only one Mosfet SI3407-TP. the other one too... its like PNP / NPN circuit
                              • lotas
                                • Jan 2016
                                • 4708
                                • Russia
                                What other circuit is similar to PNP / NPN? Do you know how the switch (mosfet) to turn on the panel (T-CON) works?
                                • Diah
                                  • Feb 2013
                                  • 6416
                                  Panel 12VCC never being active circuit over all brands of TV... this mean we do have I2C to switch controller Q or IC which yours schismatic just focused on the (mosfet) self.. which this didnt help.
                                  OP . terminated this circuit at all.. and make active DIY. DC to Dc 12V regulator feed it from any point you have >12V with CAP 2200Uf 25 V and feed it it direct to T-CON fuse ( we did this DIY before over this forum ) end.
                                  • labello
                                    • Mar 2018
                                    • 252
                                    • italia
                                    No of course, that's why I'm here , to learn .. thanks
                                    • labello
                                      • Mar 2018
                                      • 252
                                      • italia
                                      Hi thanks for the reply.. you said ( we did this DIY before over this forum ) end. Where's it the post, did you remember? I want to understand more thanks men
