Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
This topic has been answered.
  • bohaboha
    replied
    Here some pics of the chart
  • bohaboha
    replied
    Originally posted by Diah
    you mean no print charts of the socket pins on PSU..! check the downside too
    yes the print chart it needs a microscope to se it . Diah do you think is it possible that the power supply can destroy the MainBoard with that looping voltage on that pin ? because i want to try the new board
  • Diah
    replied
  • bohaboha
    replied
    i would love to link me to my post..
    any way.. DIM over all brands are VCC control BL brightness supplied by MB... so how it come you have it and MB disconnected as you said ?
    I do not really know if it is ANA_DIM but as i said in post 88 "on this PS there is no full value specification of the connector CNM801"
    and the diagram on the board is a same as in my post 88 so i suppose it is it . have to us microscope to read it. here some pictures of the legend .
    When MainBoard connected only the 12V is present no backlight and all the low voltage 2.5V ,3.3V and 4.5V disappears
  • Diah
    replied
    Originally posted by bohaboha
    Yes you did . but i have try repair it for a mother of 2 kids that are without tv now and i feel very sorry for them . now as you said i took this board 58 inches but i want to fix this floating voltage on power supply before i connect the new board.
  • bohaboha
    replied
    what.. hahahah when i said or write this. post #36 was talking on even Panels how shit they are LOL
  • Diah
    replied
    Hello again to all of you who helped in this thread and the rest of you who hope to be able to contribute with some suggestions.
    Now I have received a replacement MainBoard for this model a BN 41-02751B-000 number on the circuit and BN94-15566L ON THE STICKER
    it's for a 58 inches min is 70 inches was told by Diah that any even mainboard with even numbers would fit.
    Now I don't dare to try the table on my set because I'm a little suspicious about an uneven current coming from Power Supply to Mainboard
    on this PS there is no full specification of the connector CNM801
    the upper row the lower row of the socket
    1)GND 2) ANA_DIM :2.54 loop1.754V t
    3) A13V 4) N C
    5) A13V 6) PWM_BLU :3.35V
    7) A13V 8) POWER_ON :4.584V
    9) A13V 10) GND
    11) GND 12) GND
    the 13V is present om the upper row 12.93V
    For the STB and something named ON in the front of the CNM801 referring to 3 Jumper there must be 12.3V and 12.35V i do have 12.93V on those jumper
    the question now is why ANA_DIM is behaving that way loop from 2.5V i to 1.754
    the PSU seems to be ok because when i disconnect the Mainboard the Backlight is on but still the Mainboard must have the right voltage from the PSU and that 2.4v is enigmatic​
  • bohaboha
    replied
    3) A13V 4) N C
    9) A13V 10) GND
    11) GND 12) GND
  • bohaboha
    replied
    Hi again all lovely people. Diah now I have found a 58 Inches as you recommended that Mainboard with Even numbers would fits it is on the way hopefully already on Monday.
    Have already tried a 65 Inches as I already have it everything got started except the picture plus the STB light was on all the time and the tv did not react for the remote so I hope that wil work with this 58 would work​
  • bohaboha
    replied
    if this was only the dry pasta when you try to remove heatsink caused BGA on the SoC. , no other choice now just refllow , apply weight load on the Soc at the middle and use yours heat gun over all rand and middle. good luck
    yes i it is .it hapen that i have this IRDA SMD And BGA Rework Station T-862++ i am thinking to use to just reflow the chip but i believe i will need a good liquid flux that i do not have it now to help the situation if you know wish one i should take ? i have already solder paste 01 but i think a liquid one will be better
  • Diah
    replied
    nothing special just try t take away the black heatsink that was a bit hard to do
  • bohaboha
    replied
    [QUOTE=Diah;n3547547]stack on STBY , this is different status as the Title you stared the threat.... what did you done wrong to make the set didn't start??[/QUOTE
  • Diah
    replied
  • bohaboha
    replied
    Originally posted by lotas
    There is nothing complicated here, they are here, install a jumper between them and disconnect the U-shaped cables on the panel strips one by one...
    Doing this test suggested by apokalipto to activate pmic voltages shorting trdy1&3 test points did not change anything in tv behaviour always stack on STBY and nothing happens on screen
    here some pics mainboard without heatsink i do not find datasheet of this SDP19405
  • lotas
    replied
    i do not understand why there is 180v and 190v on the cold side of the power supply
    This is power for backlighting, it cannot be 12v.
  • bohaboha
    replied
    did you got the screen displaying image ??? so you are asking on service menu code !!!
    No Diah nothing displayed. yes am asking because none of the code is working it seems the TV freeze on STBY
    however the 12v,3.3v and 5 volt are present on the Tcon part of the board and that 5v you wanted on pin 7 is there on pin 12 instead of pin 7 but no 3.v on the lvds
  • Diah
    replied
  • bohaboha
    replied
    thank you so much lotas my eyes need to be renewed please do you have an idea why I am not able to reach Service Menue ? have tried with several codes but there might be something for this series very grateful if you can refer
  • lotas
    replied
    thank you i ll try if i find those test points quite difficult to se any inscription
  • bohaboha
    replied
    Originally posted by apokalipto
    You can activate pmic voltages shorting trdy1&3 test points, for this test you must disconnect lvds cable.
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • mrtek
    Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
    by mrtek
    Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
    11-26-2024, 09:58 AM
  • mecha1166
    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
    by mecha1166
    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
    11-25-2024, 05:22 PM
  • stinger
    Samsung UN70TU6980FXZA no sound no picture but does have backlights
    by stinger
    When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
    04-17-2024, 03:06 PM
  • mar1in
    Samsung TU8000, backlight and sound on, stuck in blue screen
    by mar1in
    I've got this Samsung here that would be stuck in a boot loop.
    After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
    Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
    Thanks in advance
    11-08-2023, 05:43 PM
