lg 60uj6300 dim backlights
  • lotas
    • Jan 2016
    • 4752
    • Russia
    Regular backlight, one strip consists of two parts (6 led + 5 led).​
    • Diah
      • Feb 2013
      • 6437
      i am interesting on the diode he mentioned... before each led have on inside... now from his talking just one for all protection.
      • Diah
        • Feb 2013
        • 6437
        if yours measurements and talking 100% correct at yours POST #19 then the issue in 2 way can say
        1- some one inter E.Z adjust service menu and changed LED BL Type.. LG have digital control of LED BL
        2- flip yours PSU and inspect the BL circuit you have several SMD low sync R . you could find one changed Value to high or open.
        • shadetreetrader11
          • Oct 2015
          • 230
ID:	3540629 Tiny surface mount diode. Looks like a protection diode to me.
          • Diah
            • Feb 2013
            • 6437
            Originally posted by shadetreetrader11
            you should test this tiny Diode when the socket disconnected.. .... if you did and its was fine... check the points i listed before
            • shadetreetrader11
              • Oct 2015
              • 230
              The diodes on the led strips measured fine. I have tested all the resistors on the back of the power supply. I also esr all the caps. Everything seems normal on power supply board. As I already posted on my 1st post I have checked all the backlight settings and that eco crap is all shut off.
              • shadetreetrader11
                • Oct 2015
                • 230
                Is it safe to say I can put the screen back together at this point and then work with either power supply or mother board or the ez settings you were talking about.
                • Diah
                  • Feb 2013
                  • 6437
                  i would leave the screen out until you have full function BL..
                  try send IN_STOP in blind way with service RC followed with 0413 . TV go to standby .. leave it 1 minute... plug it out from wall , leave it again 1 minute out. then turn on... this is shipping reset mode.
                  i still believe you have LED BL issue. yours equipment could tricking you with Values. i would use only normal DM not scope one.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4460
                    • Italy - Milan
                    #29
                    Another thread that ends to bitches.. we wait "Currents Freq", "pwm at V" and other amenities...
                    Anyway 9v of ripple sounds abnormal.. have you checked the 4 diodes i said?
                    • shadetreetrader11
                      • Oct 2015
                      • 230
                      Davi.p
                      yes I unsoldered one leg of each diode and tested them. Also checked the caps with esr meter as well.
                      • shadetreetrader11
                        • Oct 2015
                        • 230
                        Well I put it back together and it's working. (Not sure how long) ha ha. Hopefully it was just a solder joint but I highly doubt that. I guess I'm curious if leds can have intermittent faults, or generally speaking are they normally good or bad?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4460
                          • Italy - Milan
                          #32
                          i would not hope, it will fail again.. i would do a YouTube RBGWB video test to see if there are dark blotches.. i would do an ultimate effort to do some other resolder in the led power booster section of psb so you can stay more quiet..
                          • wnlewis
                            New wire for my RDE3340 Whirlpool electric range
                            by wnlewis
                            OK. I got the rocker switch figured out thanks to the good advice on this forum.
                            Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                            This is a Whirlpool RDE3340 electric range.
                            The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                            Where may I find parts...
                            01-08-2025, 11:21 PM
                          • emeskay
                            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                            by emeskay
                            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                            08-06-2024, 07:13 AM
                          • technicalspecialist
                            Vintage fan repair, copper wire question
                            by technicalspecialist
                            I currently have a customer's vintage fan on the work bench to repair.
                            It uses an induction motor with 4 poles. One of the poles is open.
                            I couldn't find the break so i cut off the original wire.
                            I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                            I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                            The enamelled copper...
                            03-16-2023, 12:54 PM
                          • max789
                            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                            by max789
                            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                            I made the following tests:
                            1. Disconnected the main board from Power Board = backlight works.
                            2. Connected the main board and disconnected the T-Con = backlights does not work.
                            So I ordered a main board from Ebay also BN41-02156A but from...
                            01-18-2024, 06:56 AM
                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                            12-16-2023, 08:39 PM
