lg 60uj6300 dim backlights
  • shadetreetrader11
    • Oct 2015
    • 230
    Have a lg 60uj6300 that has a very dim backlight. I have tried shutting all the eco settings off and no change. If I use my led backlight tester it lights the backlights nicely.(I'm not able to see if they are all lit but definitely much brighter) This tv has 2 wires from power supply to backlights. The black wire has 260v and the white wire is measuring 15.1v. Any ideas?
    ms 2.07
    pdim .265
    pwr-on 3.3
    the remaining pins are all labeled 13.2 and they all measure 13.1
  • lotas
    • Jan 2016
    • 4752
    • Russia
    Who measures the voltage at the backlight output like this, you need to measure between the white and black wires.
    And PDIM - .265v (backlight brightness level) is low...
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4460
      • Italy - Milan
      try jumpering Ms-Pdim..
      • shadetreetrader11
        • Oct 2015
        • 230
        Lotas my bad. Remeasured across black and white and I get 247v. I jumped Ms-pdim and it actually dropped the voltage of the backlights to roughly 90v.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4460
          • Italy - Milan
          247v is too high , you are maybe reading a pulsanting voltage due to bad final el.co.
          • shadetreetrader11
            • Oct 2015
            • 230
            When I put my led tester across the leads that feed the backlights it goes full bright at 168v and 90 mil amps. And when I plug the connector back to the tv power supply that is putting out 247v it's extremely dim. Why so dim? If my voltage is at 247v wouldn't it be drawing some current to fully light the leds? I'm confused
            • shadetreetrader11
              • Oct 2015
              • 230
              Picture of scope reading across the two wires from psb to leds
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4460
                • Italy - Milan
                Oh well, this lets me think of bad leds.. 90mA is quite low and it is not surely full brightness
                • zomi
                  • Nov 2011
                  • 509
                  Is there any blue purple tint to the lcd ?
                  • shadetreetrader11
                    • Oct 2015
                    • 230
                    Zomi. Yes there is a blue/purple tint sorta half lit
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4460
                      • Italy - Milan
                      this is a further clue of bad leds..
                      • zomi
                        • Nov 2011
                        • 509
                        Change the leds, they are gone.
                        All lg's blue tint change ---> leds.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4460
                          • Italy - Milan
                          I think it's strange too the so high voltage, one booster is regulated for a certain maximum, that max is printed on the pcb table, so i would check those 4 diodes in top left corner, it seems a graetz bridge that gets current from transformer, if one diode is open, the thing works at half sinewave and the booster fails to work...
                          • shadetreetrader11
                            • Oct 2015
                            • 230
                            Took it apart and leds look fine.
                            • shadetreetrader11
                              • Oct 2015
                              • 230
                              I also checked the diodes and they were good.
                              • Diah
                                • Feb 2013
                                • 6435
                                how they look fine ?? from your measurement listed at first post you have shorted zener diode at one or more LEDs
                                this LG LED are build in zener diode at reverse way to diode light... need to test one by one in diode mode... and the reading of zener should be no less than 0.65 pulling current
                                shorted zener or open will pass by LED tester... and will never discover them
                                • shadetreetrader11
                                  • Oct 2015
                                  • 230
                                  Lotas posted that .265v on pdim was to low. Is this .265 coming from the mother board?
                                  • Diah
                                    • Feb 2013
                                    • 6435
                                    no one mentioned over here the Nature of the LED unit build in this Set...
                                    take it apart and test yours LEDs with diode mode you will find the issue at zener diode.
                                    • shadetreetrader11
                                      • Oct 2015
                                      • 230
                                      All diodes have point .74 v and no shorts. I also individually checked each led with meter in diode mode. One direction lit the led and the other did nothing. There is 5 rows of leds. Each row has 11 leds. 2 pieces connect together. One has 5, the other has 6 leds. I powered up the backlights again using the tvs power supply and measured the voltage across the tiny surface mount diodes mounted on the strips. The strips with 5 leds measured 12.8 v across them. The strips with 6 leds measured 15 35 across them. Everything looked correct to me. But if I'm missing something I'm all ears. Thanks
                                      • Diah
                                        • Feb 2013
                                        • 6435
                                        interesting what you write--- show me the strips please , the label of them and the tiny diode you mentioned
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                        • technicalspecialist
                                          Vintage fan repair, copper wire question
                                          by technicalspecialist
                                          I currently have a customer's vintage fan on the work bench to repair.
                                          It uses an induction motor with 4 poles. One of the poles is open.
                                          I couldn't find the break so i cut off the original wire.
                                          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                          The enamelled copper...
                                          03-16-2023, 12:54 PM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
