PW.168W2.801 no 5v SB for sharp 55BL5KA TV
  • DiamondTech61
    • Aug 2021
    • 63
    • united kingdom
    I have a PW.168W2.801 PSU that is getting no power on the 5v SB pin, nothing looks burnt on the PSU itself, I have removed everything and Im getting over 300v on the main capacitor. I have the LED cable connected in the pic but have removed it for testing, any help is appreciated.
  • R_J
    • 9624
    It looks like T101 is the standby transformer, which is driven by Q101, there is a pwm ic (u101) that drives Q101, Remove HS5 heat sink and check R148, if it is open, Q101 is likely shorted and U101 and components in the gate drive circuit may also be damaged
    • DiamondTech61
      • Aug 2021
      • 63
      • united kingdom
      R148 is reading as 000.5 ohms with q101 removed, can test q101? is it a transistor? it looks like it says SVS7N65F
      SL9KT0G any help on testing would be great​
      • R_J
        • 9624
        SVS7N65F is a mosfet, R148 is in the mosfet source pin to hot ground, so I suspect the mosfet is ok.
        With all the parts reinstalled check if you have voltage across E106 or to check this voltage place your negative probe of your meter on E201 (-) and your positive probe on D105 cathode, you should have around 25vdc
        Can you provide a photo of the back, trace side of the board, especially for the standby circuit area
        • DiamondTech61
          • Aug 2021
          • 63
          • united kingdom
          E106 keeps jumping 8,9,10,8,9,10v continuously, E201 - to D105 cathode is the same. I did rip the trace on the part i removed but have temporarily put a wire across
          • R_J
            • 9624
            Check that you don't have a short on the 5vstby output, check that D101 is not shorted, it is a dual diode so check it in diode mode between center pin and each of the other two pins. D101 actually supplies +12v to that small standup board PWB1 which I believe supplies the standby 5v
            J29 should be cold ground and J28 should be +12v check that there is no short between these two jumpers, and if there is no short, check what voltage you get across the two jumpers.
            Are you getting any voltage across E107 this is the vcc voltage for U101, there is a zener diode in that circuit, ZD101 and R164, check them R64 should be a low value (a few ohms)
            Also, what is the number on U101
            • lotas
              • Jan 2016
              • 4861
              • Russia
              Power Supply Sharp PW.168W2.801
              • DiamondTech61
                • Aug 2021
                • 63
                • united kingdom
                thanks for your help! J28 AND J29 ARE shorted! I cant really see U101 very well but have taken a pic
                • DiamondTech61
                  • Aug 2021
                  • 63
                  • united kingdom
                  GUYS YOUR ARE LEGENDS!!!!!!! Ive sorted it, on the stand up board there a 3 SMD capacitors, one was shorted, Ive removed it and now got 5 and 12v standby! Thank You SO MUCH!!!!!!!!!
                  • lotas
                    • Jan 2016
                    • 4861
                    • Russia
                    OB2273 (OB2273CMP) marking 273**
                    • princekay
                      • Jul 2025
                      • 4
                      • GHana
                      hi guys ,please can someone please help me out with the firmware for PW.168W2.801. MY TV is stuck at the logo stage and i need it to flash it.
                      thank you
                      • lotas
                        • Jan 2016
                        • 4861
                        • Russia
                        thank you
                        What firmware can be in the PW.168W2.801 power supply?
                        • princekay
                          • Jul 2025
                          • 4
                          • GHana
                          My bad ,please the board number is T.MT5522S.82.
                          thanks
                          • lotas
                            • Jan 2016
                            • 4861
                            • Russia
                            What is the TV model, what is the panel number, what firmware is needed via USB or dump eMMC?
                            • princekay
                              • Jul 2025
                              • 4
                              • GHana
                              its a Bruhm 65" TV,Model is BTF-65SS. and its board number is T.MT5522S.82. Thank you for all your help. I am not really a repairer but my TV just suddenly messed me up. Am able to experiment with using a different board with a known firmware and luckily it worked for me. Hopefully I am happy to be on this platform to also share and assist .AM also a Computer guy so am open to assist .Thanks
                              • lotas
                                • Jan 2016
                                • 4861
                                • Russia
                                I didn't understand, do you need the firmware or not, if you do, then which one via USB (there is another company, with the same motherboard and 65 diagonal panel) what is your panel number, not like "HV650QUB-N9A"? Or do you need an eMMC dump for firmware via a programmer?
                                • princekay
                                  • Jul 2025
                                  • 4
                                  • GHana
                                  I would have needed the firmware via USB but like i said , I have decided to change a motherboard on the TV so am ok now. Thanks so much !!
                                  • lotas
                                    • Jan 2016
                                    • 4861
                                    • Russia
                                    OK!
                                    • advant
                                      by advant
                                      02-03-2020, 12:25 AM
                                    • sefoster
                                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                      by sefoster
                                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                      11-20-2022, 09:29 AM
                                    • gavenb
                                      Sharp LC-80LE661U 80 inch
                                      by gavenb
                                      Hi folks!
                                      I have a LC-80LE661U that had some interesting issues.
                                      Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                      I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                      11-12-2023, 02:05 PM
                                    • SONY_E-WASTER
                                      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                      by SONY_E-WASTER
                                      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                      does...
                                      12-26-2021, 05:46 PM
                                    • Superbee_dad
                                      Sharp 80” long short flash backlight error - Help
                                      by Superbee_dad
                                      Hello Sharp TV experts
                                      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                      01-24-2025, 11:51 PM
