Sony KD-60X6700E not turning on
  • lotas
    • Jan 2016
    • 4838
    • Russia
    Originally posted by sabretooth
    I pulled up a leg on each (just to rule out any other variables) - D660A appears to be short.
    Well, replace it, or better yet, two at once and I hope that your TV will work.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4534
      • Italy - Milan
      "appears" or IS?
      • lotas
        • Jan 2016
        • 4838
        • Russia
        The markings on it are: SR206 734Y
        SR206 - Schottky Diodes 2A, 60V
        • sabretooth
          • Apr 2012
          • 62
          Originally posted by Davi.p
          "appears" or IS?
          It was an expression, but yes that's what my meter tells me.
          Fantastic - thankyou. I'm hoping it's that simple!
          Once I've done it, I'll report back on how it went.
          • lotas
            • Jan 2016
            • 4838
            • Russia
            When installing new diodes. Observe their polarity (anode-cathode).
            • R_J
              • 9623
              Good to hear you found the problem, knowing that R601 was ok, so ic600 is likely ok as well. checking the secondary diodes was the next components to check so replacing them should fix the standby supply.
              • Diah
                • Feb 2013
                • 6545
                however its unusual 5V circuit D660A get shorted..,
                1- there are over load at MB DC tp DC circuit
                2- SMD parts on downside carefully test them. if there one have leak and make overload.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4534
                  • Italy - Milan
                  #28
                  I see various ceramic caps at valley of faulty diodes, better to check them also..
                  • lotas
                    • Jan 2016
                    • 4838
                    • Russia
                    #29
                    These Schottky diodes in secondary power supplies burn out just like that (not only in Sony, but also in Samsung, Lg,...), not often, but they burn (turned it off in the evening, the TV doesn’t turn on in the morning), just like ceramic ones capacitors - they just short out, replace them with new ones and everything works..
                    • Diah
                      • Feb 2013
                      • 6545
                      These Schottky diodes in secondary power supplies burn out just like that (not only in Sony, but also in Samsung, Lg,...), not often, but they burn (turned it off in the evening, the TV doesn't turn on in the morning),.
                      comm on we do have many stay over night or 2-5 days in STBY .... LOL... this is never being the cause.... only over load.from MB or its self circuit
                      if he check the 5V pin on MB with ref TV chassis he will find low resistances
                      in General Diode will be active in side it material only if there are Load at end of out put
                      • Diah
                        • Feb 2013
                        • 6545
                        on other hand... lotas you found fault... and my talking on why this fault happen.... if there are issue as i mentioned before we are going to roasted complete TV.
                        the cleverness here at any one want or like to be repair of electronic.. when he find fault... before he repair it by replacement, should know and discover why this happen... at least this is my method & WAY
                        • lotas
                          • Jan 2016
                          • 4838
                          • Russia
                          #32
                          I already wrote that they can short out just like that and not because of motherboard overload, why they short out SMD ceramic capacitors and everyone is looking for the reason why they burn, the components do not have a lifetime service life, they are not eternal...
                          • Diah
                            • Feb 2013
                            • 6545
                            i can answer this questions... SMD ceramic they shorted for 2 reasons. 1- quality .. 2 - over clock Freq. and this most happened because of the first point of bad quality material.
                            but still the questions .. unusual 5V circuit D660A get shorted.... some one work or tested in wrong way .... or some one play to MB.... from alone as RAW fault never never happened and will never happen. point.
                            • lotas
                              • Jan 2016
                              • 4838
                              • Russia
                              #34
                              Now, if OP replaces these diodes and when turned on, whatever the diode closes again, then we need to look for the reason, and maybe there is a defect in the transition of the crystal, a pulse current that exceeds its characteristics...
                              • Diah
                                • Feb 2013
                                • 6545
                                my friend... you are correct in way if there are no more fault and STBY TV work.... but if the Diode fly out again it will fly with it many others...
                                this could not happens... but any one should avoid expressive repair when the fault just few cents coast..... test ... test... look for reason..
                                • lotas
                                  • Jan 2016
                                  • 4838
                                  • Russia
                                  #36
                                  If the diode fails, then the same thing will happen, the PWM will go into protection and there will be no voltage at the output, but let’s hope that everything will be fine.
                                  • Diah
                                    • Feb 2013
                                    • 6545
                                    If the diode fails, then the same thing will happen, the PWM will go into protection and there will be no voltage at the output, but let's hope that everything will be fine.
                                    PWM no protection here. transformer will eat it and .. the Optocouplers between hot / Cold will be the first victim to deliver RAW.... now we have the begin of horror movies
                                    • sabretooth
                                      • Apr 2012
                                      • 62
                                      As a result of your discussion and suggestions, I did some more poking around that valley of surface mount components. The two 20R0 resistors there (R660A, R660B), are reading 10ohm each (I haven't removed them from the board).
                                      I assume to the right of those are caps - C660A, C660B. I'm not getting anything from these in diode mode - yet the other caps in the area are showing a reading. So are these caps dead too, or do I need to measure them differently?​
                                      For what it's worth, I've owned this TV since new and I'm the first person to open it up.
                                      If the caps are dead too, I'm not sure what I'd replace them with. I assume I'd need a schematic or a donor board?
                                      Speaking financially, there aren't a lot of options where I live for replacement components. I can get a pack of diodes for $11. I can also get a replacement power supply board for $42, so I'm tempted just to go that route. Is there anything I should check on the main board that might be causing issues on the power supply board? Or would I be safe to replace the power supply board?
                                      • lotas
                                        • Jan 2016
                                        • 4838
                                        • Russia
                                        #39
                                        Resistors with a resistance of 20 Ohm are connected in parallel and will show 10 Ohm each. Capacitors will not show anything on the multimeter unless they are shorted. Install new diodes and turn on the TV, otherwise you will read horror stories about how many times you have repaired such breakdowns, not when there were no returns for the same reason.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4534
                                          • Italy - Milan
                                          #40
                                          Too much Ambulance stories here for me, it was enough to say replace diodes (we know smd are ok) and test first the PSB alone , also with no loads, then attach to the rest if ok, no risks, no ambulance crysis.. ahah..
                                          PS: every SMPS on the globe is protected to the short circuits, here we are at basic school..
                                          If the tv does not boot, then the fault reason is all clear, power spike damaged both PSB and MB..
                                          • NSkyLab
                                            Sony XBR-65X900F black and white image on one side (fading saturation)
                                            by NSkyLab
                                            I though I've seen all possible kinds of failures but this one is new...
                                            Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
                                            I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
                                            Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?...
                                            10-05-2025, 07:37 PM
                                          • Watson306
                                            6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                                            by Watson306
                                            I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                                            I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                                            I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                                            Many Thanks in advance.
                                            11-01-2022, 05:33 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • ptcriserx3
                                            Sony trinitron crt bowed and side color issues
                                            by ptcriserx3
                                            Hi
                                            Ive got a vintage 2001 sony trinitron flat tube tv
                                            The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                            See many images attached...
                                            Just windering if this is not fixable or something i can correct without getting too invloved
                                            Im trying to sell the tv
                                            06-17-2023, 07:27 PM
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
