LG 37LH5000 boot loop due to shorted inverter
    First time I had this. Inverter was shorted (fuse still OK.) As soon as inverter supply came up, TV rebooted, causing it to get stuck in a boot loop. Unplugging inverter allowed TV to power up fine with no backlight.
    I found BD9215AFV burnt plus two FDP8447L MOSFETs shorted.
    I am trying to source BD9215AFV now, the FETs were easy enough.
    • 31157
    Re: LG 37LH5000 boot loop due to shorted inverter
    $9 for one
    http://www.ebay.com/itm/201086770501
    $38 for ten
    http://www.ebay.com/itm/191066810286
      Yeah I saw that but I don't feel like waiting 2-3 weeks. I'm trying to find one closer to home.
        • 31157
        digikey has them,
        x for the chip, x x2 for the postage!
          Plus import fees... I got bit by that last time!
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            the only one i can see really in the uk is chs
            http://www.chsinteractive.co.uk/elec...al-i-c-smd.htm
            bit pricey and postage high imo.
              Have ordered from CHS, only UK source... Bloody expensive!
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                i tried the shop i use in birmingham too they didnt stock it either chs very expensive anyway hows you plasma still running good i hope?
                  The Kuro is still working fine, I've since moved it into the new house.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    cool that was a nice easy fix then also i hope you fix this lg inverter too with the price of that part!
                      Hmm :/. I finally fixed the inverter issue, turned out there was a small 10k resistor O/C on the inverter board, feeding the STB pin of one of the BD9215AFV IC. It's only current limiting into an IO port, so I subbed it with a 22k and it worked. The TV turns on and the backlight lights, however, it makes a hideous buzzing sound (worse than chalkboard grating), and a portion of the screen does not light.
                      I suspect there is a short in the panel... bulb to chassis... yay...
                      I will have to take the panel apart to repair it.
                      • sven337
                        • Jun 2014
                        • 6
                        • France
                        I'm working on a similar inverter from a LG TV. The board is referenced 6632L-0549A, and it sports 4 transformers, 8 MOSFETs. The BD9215AFV was OK, but it was the slave chip BD9898FV that was dead, as well as three shorted MOSFETs.
                        I've replaced everything (replacing the BD9898FV was very tedious, I unfortunately destroyed a trace or two so had to fix things up with wire), and the inverter seems to at least start up, but it still doesn't appear to work.
                        Since I suspect you are working on the exact same board, I'm asking here:
                        There is a LED on the inverter which lights up for a short time when I power up the TV, then it appears to continue its "boot loop" just like before. Any idea what logic drives the LED?
                        There's also a strange part on the board, under a blob of glue, next to silkscreen that says "REG". Any idea what this can be?
                        I haven't yet looked at the "status" pin of the inverter, I suspect it's detecting a fault somehow (either because I botched my repair job or because some other part is broken) and telling the TV to stop.
                        What is this resistor you are talking about? What was the fault?
                          Are you sure the chips are different? I thought both were BD9215AFVs?
                          Mine still isn't working, the LED does now light up, I think it indicates the ignition phase for the bulbs but I haven't found any further info or documentation. In the middle of a house move, so won't be able to have a look at it again for a while.
                          • sven337
                            • Jun 2014
                            • 6
                            • France
                            I'm sure the chips are different. BD9215AFV is the "master" (according to the datasheet), and BD9898FV is the "slave" (again, according to the datasheet, I'll confess not having given much attention to what those chips do exactly). BD9898FV burned when I tried to start the inverter with the broken MOSFETs removed (not the smartest idea on the planet, but I wasn't expecting the chip to blow...).
                            So I sourced it (with difficulty), and replaced it, and I get to the point where the LED lights up for about 1 second, then stops again.
                            I'm still hunting for documentation. Will post an update if I make any progress.
                            Note: I'm not sure what inverter you have, but 6632L-0549A appears to be replaceable (according to pictures) with 6632L-0579A, aka PNEL-T808B (vs T808A for 0549A). 0579A is somewhat easier to find a replacement for, in case this gets to the point where we can't actually fix the board.
                              I have the 549.
                              That might explain why it isn't working, I swear it was a BD9215AFV for both... but then again it was badly burnt and I could not make out the part # completely.
                              I spent £11 on the chip from CHS... so I am a bit pissed if I bought the wrong one!!! (Ugh!)
                              I may go for swapping the inverter. From China it's about £25.
                              • sven337
                                • Jun 2014
                                • 6
                                • France
                                This inverter's architecture is fairly complex compared to others.
                                If you need one, I managed to buy a BD9898FV at an unbeatable price: http://www.aliexpress.com/item/Bd989...080638181.html
                                Note the picture says BD9897FS (the most common single-chip driver for similar inverters), but the marking really is BD9898FV. Is it genuine, I don't know, since my inverter isn't working one can wonder
                                The 0579A is indeed about 25GBP (will you guys ever join eurozone?), and I'm pretty sure it's compatible with 0549A. The TV isn't mine however so it isn't my decision.
                                  • 31157
                                  NO, because then the government in the u.k. would not be able to run a printing-press 24 hours a day to hide the collapse.
                                  • sven337
                                    • Jun 2014
                                    • 6
                                    • France
                                    I wonder if the lamps themselves aren't bad. What's the likelihood that they'd be e.g. shorted?
                                    What gives me trouble is that only one wire is actually connected from the lamp to the inverter! I don't know where the other one is, perhaps the chassis is used?
                                      This is always a possibility, practically the only way to be sure is to take the panel apart.
                                      • sven337
                                        • Jun 2014
                                        • 6
                                        • France
                                        Two of the three FETs I've replaced were shorted again after a few minutes of experimentation. Perhaps the lamps are bad, or the transformers - anyhow I give up. I may attempt to replace this inverter (6632L-0549A) with an apparently compatible, used 6632L-0579A, but I'm not sure this is worth the expense.
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • S14Sr20det
                                          Samsung QN65Q60RA boot loop “shorted lcd” repaired
                                          by S14Sr20det
                                          Hello all. First time posting but long time lurker here.
                                          First off I am not expert but I do know my way around electronics and have a fairly good grasp on troubleshooting them.
                                          I acquired this tv for free from a neighbor who had a repair man out and diagnosed it having a shorted lcd panel.
                                          Symptoms were that I would start up and reach the Home Screen and work for thirty or so seconds then the lcd would fade to black and enter a boot loop where it would get shorter with each attempted boot.
                                          Went through the basic trouble shooting...
                                          04-01-2023, 11:22 AM
                                        • blaster_
                                          Samsung UE49MU6105K - boot loop, horizontal lines
                                          by blaster_
                                          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                          06-22-2022, 05:19 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
