Samsung QN65Q60RA boot loop “shorted lcd” repaired
  • S14Sr20det
    • Mar 2023
    • 5
    Hello all. First time posting but long time lurker here.
    First off I am not expert but I do know my way around electronics and have a fairly good grasp on troubleshooting them.
    I acquired this tv for free from a neighbor who had a repair man out and diagnosed it having a shorted lcd panel.
    Symptoms were that I would start up and reach the Home Screen and work for thirty or so seconds then the lcd would fade to black and enter a boot loop where it would get shorter with each attempted boot.
    Went through the basic trouble shooting of disconnecting components until it would stay running and settled on the left most lcd interface strip (buffer board?)
    From there I felt the components to detect heat. Found three resistors heating up and an esd diode array getting very very hot.
    I broke out my meter and started to probe around and I found a leg on the diode with a direct short to ground. No ohms at all!
    Ordered 6514p diode array from Digikey and very carefully removed the old and installed the new. ( short disappeared after old one removed)
    Plugged it in after verifying that short no longer exists and I have a free working tv that was destined for the land fill. Well.. maybe not free I paid 1.19 for the diode. But still. I hope this helps other people and I have attached photos. Sorry I didn't record or document it better as I had little faith that it was actually going to be successful.
    Last edited by S14Sr20det; 04-01-2023, 11:30 AM. Reason: Added two more photos screenshotted from a video that I could not manage to up load showing melted flux to verify heat
  • nomoresonys
    • 12312
    • U.S.
    Re: Samsung QN65Q60RA boot loop “shorted lcd” repaired
    Good work, yep those packs have caused many problems, have some threads here on them, nice solve.
    • S14Sr20det
      • Mar 2023
      • 5
      Thanks! I had read as many threads as I could and each one never exactly had a happy ending. Some people had lines or just never answered at all. But I wanted to make sure to contribute to this website since it led me down the path of this repair and hopefully other people can also do this.
      I will add that this is my first time doing a component level repair on a package size of 1mm x 2.50mm! With ten leads on it. You most definitely need steady hands tweezers and thermal tape to keep from contacting and moving other componets. I also wet a towel with alcohol and placed it under the cof cables to avoid the heat from delaminating them. I suppose you could just knock the diode off all together too but you would have no protection against static in the future since the traces run under Meath and not “through” the array.
      • nomoresonys
        • 12312
        • U.S.
        I see, that is a tough one for your first component repair, well done indeed.
        • Takeatry
          Yet another Samsung QLED Boot Loop
          by Takeatry
          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
          10-04-2024, 02:57 PM
        • torchzack
          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
          by torchzack
          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
          08-28-2023, 07:42 AM
        • NolesFan
          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
          by NolesFan
          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
          10-24-2024, 06:36 PM
        • eigma
          Samsung UN40H5003 boot loop every ~8 seconds
          by eigma
          Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
          Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
          SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
          Main board: BN94-07592P / BN97-08922R...
          11-20-2024, 10:31 PM
        • blaster_
          Samsung UE49MU6105K - boot loop, horizontal lines
          by blaster_
          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
          06-22-2022, 05:19 PM
