Vestel 17MB185 Toshiba 50qa5d63db
  • Karlito19
    • Oct 2024
    Hi I am looking for a firmware dump for this vestel board, please
  • yokoono
    • Apr 2010
    • 486
    I have this. Try at your own risk.
    https://files.fm/u/2nxvuqqnxe
    • MS1
      • Feb 2015
      • 5
      Hi. Could you share it again? Thanks
      • yokoono
        • Apr 2010
        • 486
        Panel VES500QNZH-P5-Z71 ???.
        • MS1
          • Feb 2015
          • 5
          Hi. No it's VES550QNZH-P2-Z52 (Panda PT550GT01) and Model 55QA5D63DB. I want to try it as there's nothing for my model. Unless you've got correct dump. Thanks
          • yokoono
            • Apr 2010
            • 486
            In the archive I have this:
            Toshiba 55QA5D63DB 28845892_MB185_MED_TOS_USER_SIGNED_8294449_V02212.
            Try at your own risk. Post the result. Link valid for 2 days.
            https://files.fm/u/mhwr4gmje6
            • MS1
              • Feb 2015
              • 5
              Thanks but I've already got that one. I'm looking for eMMC dump itself as mine has completely died. Thanks
              • anlu
                Vestel Firmware - Toshiba 32W133DN
                by anlu
                Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                02-04-2023, 12:59 AM
              • cheeky2
                Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                by cheeky2
                I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                Details:...
                08-17-2023, 04:34 AM
              • Tamo Neko
                Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                by Tamo Neko
                I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                What Happened:
                I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                What I Need:
                • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                02-12-2025, 11:29 PM
              • Mephysis
                DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                by Mephysis
                Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                03-27-2025, 02:34 AM
              • RAZ777
                Toshiba 40L3653DB Vestel firmware
                by RAZ777
                Hi Guys,
                I have a Toshiba 40L3653DB with flashing green/red led - firmware fault.
                It has the vestel 17MB110 board.
                Anyone know where I could get firmware?
                02-16-2022, 07:56 AM
