Vestel 17MB185 Toshiba 50qa5d63db
  • weisian
    VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
    by weisian
    I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
    1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
    2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
    03-12-2026, 05:54 AM
  • andrewaduriz
    Toshiba 43LA2063DG (Vestel 17MB171, panel VES430UNDP-N1-N42) – looking for firmware, bootloop after update
    by andrewaduriz
    I'm having trouble with a Toshiba 43LA2063DG on a Vestel 17MB171 mainboard. Details from the labels:
    • Panel: VES430UNDP-N1-N42
    • Mainboard: 17MB171, sticker number: 1910 23740548 286451820204 10128687 2990
    Background: the TV started with a black screen, so I flashed Vestel's own official firmware via USB, but it got stuck in a loop on the startup screen. I bought a replacement mainboard (it worked, just with a minor graphical glitch), but after trying to update it, it also got stuck. I then tried another firmware file I found online, but it caused worse picture...
    09-26-2026, 02:06 AM
  • lberkani
    Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
    by lberkani
    I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
    The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
    The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
    I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
    - Toshiba 65UL2163DG
    - Vestel 17MB180E mainboard
    - Panel VES650QNTX-N2-N42
    - Version V1.28.100.0 if available
    If anyone has the file, please share a download link (**********, MEGA, Google Drive) and include version.txt...
    11-11-2025, 12:37 PM
  • VertacoM
    looking for vestel 17mb185 (23851391) firmware
    by VertacoM
    I'm looking for a firmware or panel file to fix a display issue on a TV after a motherboard replacement.
    Here are the specifications of my board/set:
    • Mainboard: Vestel 17MB185
    • Software/Panel Variant Code: 23851391
    The issue: Since swapping the motherboard, the TV turns on but I have a distorted / double image on the screen, which is typical of a panel profile mismatch.
    I am trying to find the appropriate recovery package, specifically looking for the .pkg file or panel files (MDS_upgrade_image_no_tvcertificate.pkg / upgrade_image_no_tvcertificate.pkg)...
    06-02-2026, 05:13 PM
  • anlu
    Vestel Firmware - Toshiba 32W133DN
    by anlu
    Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
    Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
    02-04-2023, 12:59 AM
