Panasonic TC-L55ET5
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Panasonic TC-L55ET5
    Need a bit of advise on this one.
    I got it yesterday,turned it on,picture looked horrible,vertical bars that kinda followed the menu screen,slowly fading image into the next etc..when it warmed up picture got pretty close to perfect but then started freezing every few seconds with horrible distortion etc..
    One shot of freeze spray on mainboard and tv jumped back to functioning normal..Hasen't done it since either but im sure it will again.
    So it needs a mainboard for sure..
    Question I have is that there are horizontal lines from left side of screen towards right side,fading into perfect about 3 quarters of the screen to the right.
    They are barely noticeable from a few feet but up close clearly there...They are not black lines,more a slightly compressed picture every quarter inch.
    Tried to capture it on a pic,have a look..
    Do you think thats also caused by the mainboard or is the screen fubar???
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Panasonic TC-L55ET5
    For what my opinion is worth if it started with bars and still has bars Im going to say main board. Just curious what section of the main you sprayed? I see a large dc-dc converter section up top on the left. most of the main failures (phillips) Ive dealt with had problems in this section.
    Liberating magic smoke one part at a time
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      On pic 2 you can see that large chip with 16.000 legs? Right before the two ribbon cables? I froze that guy and tv smartened up instantly. Now if its that chip or a small smd part right beside it I don't know.
      I gambled on it all being mainboard and ordered one.
      Tnph1006. Now mine is a 1006 1a. The one I ordered is a 1006 2a. The 1 and 2 before the a are in a circle. Would that matter? They both come up as being for this TV.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        I would try to reflow that if the freeze spray cured it, nothing lost as you were already planning on buying a main... flux it good and give it a shot with some hot air.
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          Finally got a mainboard for this thing,it cured the crashing and weird picture BUT the fine lines from left to right (Starting strong on left side of screen fading away to perfect about 3/4 of the way to the right) is still there
          What's next? T-con? or is that a bad panel sign?
          Right now I'm using it as my PC monitor,playing DAYZ and BF4 on a 55" tv is awesome . In game you barely notice the lines,but on being on this forum you can clearly see that there is something wrong with the picture...
          • SACR
            Panasonic Plasma TH-P42X28K A-Board @ Mainboard Schematic needed
            by SACR
            I need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...
            11-20-2023, 11:53 PM
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here๐Ÿค”?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting ๐Ÿ˜‚.
            11-20-2024, 08:52 PM
          • rui4892
            panasonic TX-47AS650E solarized and mirror image after change mainboard.
            by rui4892
            hello everybody.
            my previous post disappeared, perhaps due to the server transition... but let's move on...
            I bought a similar board on ebay but this one is programmed for the 48FHD panel, my panel is 47FHD... in the service manual I can't find information on how to change it... or what to change... thank you.โ€‹
            11-27-2023, 04:48 AM
          • Mirenia
            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
            by Mirenia
            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
            03-30-2025, 06:47 AM
