Philips 47PFL4007T weird behaviour
  • PowerAmpFreak
    • 982
    • Sweden
    This Led TV does act very strange. It certainly appears to be a mainboard issue. I will anyway tell what happens:
    Every time the mainscord is pulled and put back in, the TV will show a "timeglass" on the screen for a while. Then all black.
    After 30 seconds or so, the screen does come on, and set behaves more or less OK.
    If the set is put to standby, there is sometimes impossible to bring it back to operation, without pulling the plug.
    Any "bells" ringing out there?
    I was checking its FW according to Philips site it has the latest one available.
  • R_J
    • Jun 2012
    • 9625
    Re: Philips 47PFL4007T weird behaviour
    from the picture, that standby cap looks like it could be bad
    • PowerAmpFreak
      • 982
      • Sweden
      Funny guy
      • R_J
        • Jun 2012
        • 9625
        I found this in the owners manual :
        The TV does not respond to remote
        control or front controls when switched
        on:
        The TV requires some time to start up.
        During this time, the TV does not respond
        to the remote control or front controls. This
        is normal behaviour
        I guess some Philips tv's depending on the software willl display the timeglass or the Philips logo while booting up and some will just remain black screen while booting.
        If its a new tv contact Philips, could be a problem with the main board?
        • estabilito
          Acer Nitro AN515-55 weird behaviour on startup
          by estabilito
          Hi, I've just repaired acer nitro an515-55 with specs:
          i7-10750h, rtx2060.
          Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
          After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
          i've tried different bios, different vbios and same behaviour - clean windows install too.
          Do you have any idea?
          08-13-2025, 02:52 PM
        • arashmoayyedizadeh
          A1990 2019 touchbar weird behaviour
          by arashmoayyedizadeh
          Hello to all of you engineers
          i have a macbook pro a1990 in no power condition
          another shop had done some works on it with no success (pm ic was reflowed, a little bit of flux around one of the type c rom ic, changing the charging ic)
          initial state: 5v 0amps on all 4 type c sockets
          after some inspections i realized the charging ic that another shop installed is isl9239
          I changed it with right one (isl9240) and the machine turned on and booted into macos
          weird behaviour:
          Lcd works ok until it boots to os and as soon as you see login page it goes black...
          03-26-2025, 12:02 PM
        • Gueric
          MacBook Pro 820-02020 Weird behaviour
          by Gueric
          Hey mon2, it’s me again. My Mac worked fine a full week, then did the same thing again. Charger would not do anything once plugged in, and battery wouldn’t charge. It’s currently drained,
          And only reacts/shows a charging icon when plugged into the top port (slave CD3217, that I replaced 6 months ago). Plugging it in the master port doesn’t do anything.
          the trackpad clicks for some reason, even with the charger unplugged.
          despite hearing the charging chime and leaving it like that for a while it’s still showing this charging icon. I don’t have access...
          08-04-2025, 09:59 AM
        • Ierwin
          Philips 58PUS7805 Menu working but no/weird picture from video sources
          by Ierwin
          I got a 58pus7805 that shows some weird behavior.
          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
          I managed to install the latest official firmware by holding the control button while plugging...
          03-10-2024, 12:50 PM
        • estabilito
          Acer E5-573g weird behaviour
          by estabilito
          Hello, i have in hands: E5-573g mb code: da0zrtmb6d0 rev D and it works weird:
          When i plug the ac adapter to the wall socket and then plugging in dc jack to the laptop - laptop is clicking and doesnt turning on.
          Weird thing is that when i first plug the dc jack into laptop and then plug the power cord to the wall socket - laptop turning on but doesnt charging battery - showing in windows "battery charging" but even after 24hours connected, battery is still 0%.
          I replaced the charger - no effects - same behaviour,
          i' ve changed the battery and...
          04-27-2022, 11:38 AM
