MacBook Pro 820-02020 Weird behaviour
  • Gueric
    • Feb 2025
    • 72
    • France
    Hey mon2, it’s me again. My Mac worked fine a full week, then did the same thing again. Charger would not do anything once plugged in, and battery wouldn’t charge. It’s currently drained,
    And only reacts/shows a charging icon when plugged into the top port (slave CD3217, that I replaced 6 months ago). Plugging it in the master port doesn’t do anything.
    the trackpad clicks for some reason, even with the charger unplugged.
    despite hearing the charging chime and leaving it like that for a while it’s still showing this charging icon. I don’t have access to an ampmeter right now I’m on vacation.
    do you have any guess what could be the root cause of this ?
    Thank you very much
  • mon2
    • 14726
    It is because you are on vacation. Murphy's Law.
    Not understanding about the trackpad clicking concern. If there is enough power in the battery, the logic board will allow the haptics on the trackpad to function normally.
    Start with the USB-C meter readings for the voltage and current draw. Be very careful about the plugging in and out of the USB-C connectors while being 'hot on the AC power. The USB-C spec is a failure IMHO. The fact that you can easily cross short the many lines on the connector, there is always a risk. While you are charging, the adapter is @ 20v and if you remove while it is 'hot' @ 20v, then 20v is hitting the dainty USB-C lines and causes destruction to the PD controller, etc.
    Do check the USB-C connectors on the paddle board on the logic board. Perhaps some clues there.
    • Gueric
      • Feb 2025
      • 72
      • France
      Im starting to think aswell that USBC is kind of messed up, especially in MacBook with a power sequence longer than my arm.
      what do you think of draining the battery as much as possible to a point where the trackpad wouldn’t even click and the battery icon would stop showing up (by repeatedly pressing keys for example) and then plugging it to power ?
      mon2
      i ordered an infiray P2 Pro. It’ll help for future repairs, and maybe with my own Mac too.
      • mon2
        • 14726
        If you are doubting the battery - just test with another known good unit from Amazon or similar. With Amazon, you can simply return it if not required. Respectively, disconnect the battery to test if the trackpad will click or not without the battery.
        I would take voltage measurements of the key power rails to see if something else is taking down the power on sequence. Personally finding the very tiny parts to be nearly impossible to work with on the relatively newer models. While working to service one part, another goes dancing, etc. A true balance of heat; air pressure and a steady hand.
        • rilley
          MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
          by rilley
          I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
          I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
          My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
          And the resistor L4004 is literally burned.
          From what I see from the schematics, it does not affect any other rails, only the connection to the display...
          07-10-2024, 01:57 AM
        • estabilito
          Acer Nitro AN515-55 weird behaviour on startup
          by estabilito
          Hi, I've just repaired acer nitro an515-55 with specs:
          i7-10750h, rtx2060.
          Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
          After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
          i've tried different bios, different vbios and same behaviour - clean windows install too.
          Do you have any idea?
          08-13-2025, 02:52 PM
        • envym
          by envym
          Hi everyone!
          06-27-2025, 08:54 AM
        • bigbadbios
          a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
          by bigbadbios
          I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
          When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
          I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
          Your help is GREATLY appreciated. Thanks!
          08-18-2024, 05:47 PM
        • brockauly
          Macbook M1 A2337 EMC 3598 weird battery charging problem
          by brockauly
          Hi guys,
          If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
          Then if I unplug the charger and plug it back, it won't charge anymore.
          In the first case, main voltage is regulated at ~12.5V and charges the battery.
          After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
          After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
          I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
          02-05-2025, 10:51 AM
