A1990 2019 touchbar weird behaviour
  • arashmoayyedizadeh
    • Jan 2022
    • 61
    • Iran
    Hello to all of you engineers
    i have a macbook pro a1990 in no power condition
    another shop had done some works on it with no success (pm ic was reflowed, a little bit of flux around one of the type c rom ic, changing the charging ic)
    initial state: 5v 0amps on all 4 type c sockets
    after some inspections i realized the charging ic that another shop installed is isl9239
    I changed it with right one (isl9240) and the machine turned on and booted into macos
    weird behaviour:
    Lcd works ok until it boots to os and as soon as you see login page it goes black but if you connect to external monitor both internal lcd and external monitor work very fine,if you disconnect the external monitor , after a couple of seconds the lcd goes black too
    reconnecting the external monitor doesnt work any more untill you turn off and turn it on again (it should be connected during boot)
    What i did: reprogram the type c rom ic that i mentioned above (it was identical with good dump and may be just was reflowed)
    perform a dfu restore successfully
    re install latest mac os on device (during installation it was ok until the section you should insert information and costomizing os and in this moment lcd went black
    i connected to external and both internal and external was ok as i mentioned and i completed the instalation
    So far the problem persists
    I would really appreciate ane guidence or clue
    thank you very much
  • reformatt
    • Feb 2020
    • 1549
    Lid sensors checked?
      • Jan 2022
      • 61
      • Iran
      Yes, lid sensors are ok
      i booted the machine into safe mode and lcd worked perfect , closing the lid will put the machine into sleep and it will be ready as soon as you open the lid
      in normal boot another thing i realized is: only the image will go blank , the backlight is activated an on
      i dont know why the lcd works perfecf in safe mode
      • reformatt
        • Feb 2020
        • 1549
        Being an A1990 it has CPU and GPU graphics and sounds like one isn't working properly when it's flipping from one to the other or or when the kext is loaded. The MUX chip comes to mind (U9850) as that's commonly damaged when you have liquid damage in the LCD connector. Might be a bad GPU.
          • Jan 2022
          • 61
          • Iran
          Thank you so much
          The interesting thing is when the external monitor is connected you can use all the options in display settings (main,extend,mirror) without any problems
          btw i will do some inspection around u9850 and will inform you if i find something
            • Jan 2022
            • 61
            • Iran
            Today i was searching around and i realized that macbook pro uses discrete graphics when you connect it to external monitor (amount of graphical load doesnt matter) and when you disconnect the external monitor it will be switchable due to load
            I was thinking in my case may be an issue with igpu , so i diged deeper and found a terminal command that will set gpu on discrete mode permanently
            Guss what !!!!
            The image didnt go blank and now the machine works very good on its internal lcd (with or without connecting to external monitor)
            In this way consequences are: more heat and faster battery drain
            I will appreciate if something comes to your mind​
            • estabilito
              Acer Nitro AN515-55 weird behaviour on startup
              by estabilito
              Hi, I've just repaired acer nitro an515-55 with specs:
              i7-10750h, rtx2060.
              Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
              After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
              i've tried different bios, different vbios and same behaviour - clean windows install too.
              Do you have any idea?
              08-13-2025, 02:52 PM
            • ahoonid
              MacBook A1990 vertical stripes on external screen
              by ahoonid
              Hey everyone,
              I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
              The board is neat. Not opened before for sure. Just a little dust, nothing more.
              Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
              06-20-2025, 08:54 AM
            • Gueric
              MacBook Pro 820-02020 Weird behaviour
              by Gueric
              Hey mon2, it’s me again. My Mac worked fine a full week, then did the same thing again. Charger would not do anything once plugged in, and battery wouldn’t charge. It’s currently drained,
              And only reacts/shows a charging icon when plugged into the top port (slave CD3217, that I replaced 6 months ago). Plugging it in the master port doesn’t do anything.
              the trackpad clicks for some reason, even with the charger unplugged.
              despite hearing the charging chime and leaving it like that for a while it’s still showing this charging icon. I don’t have access...
              08-04-2025, 09:59 AM
            • silver60618
              Macbook Pro A1990 - Battery not detected after connector torn off
              by silver60618
              Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
              Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
              11-12-2025, 06:36 PM
              HP ProBook 430 G6 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 430 G6 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse boardview and 430 G6 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
              09-06-2024, 08:52 AM
